1978 - 1996 Big Bronco
trans swap help
Old May 25, 2009 | 06:59 PM
birdman57's Avatar
birdman57
trans swap help
I have a 1993 Full size Bronco 351w/ E4od trans. I recently installed a 393 stroker/carbed. Was wondering if anyone knows what exactly it will take to swap out the E4od for a C6. Will a C6 bolt to a 1993 tranfer case,ect.
Old May 26, 2009 | 03:04 PM
Kemicalburns's Avatar
Kemicalburns
yes they will/should. you may need different drive shafts though as the lengths are different.
are you installing a stock C6 or built C6. have your removed all of the ABS stuff and how are you going to get your speedo and such to work>?
why did you ditch efi?
Old May 26, 2009 | 03:52 PM
85e150's Avatar
85e150
You can keep your E4OD with an aftermarket controller:
E4OD and 4R100E Performance Products
Old May 26, 2009 | 04:13 PM
birdman57's Avatar
birdman57
I have a baumanator in it right now,didnt like it and ended up blowing out high gear in my E4OD, I think i'm selling my controller and trickflow pan and going for a built C6 with stall.
Old May 26, 2009 | 11:19 PM
birdman57's Avatar
birdman57
Was going to run a after market speedo. Not sure exactly what needs to be done with the ABS. Do you know?
Old May 26, 2009 | 11:40 PM
85e150's Avatar
85e150
Sorry, no clue on the ABS deal.
Old May 27, 2009 | 03:43 PM
Kemicalburns
i just see you in for a lot more work then necessary and expense.
as for the abs i believe it will need to be ripped out so your brakes operate properly. reselling this rig at anypoint will not be possible unless its sold as offroad only though. with removal of all this stuff it wont be emissions legal or street legal.
did you contact baumanator about your tranny failure?
Old May 27, 2009 | 05:46 PM
birdman57's Avatar
birdman57
I'm not so worried about selling the truck. Plan on going to my grave with this truck.Have over 30k invested.Also I live in Wisconsin and truck is already old enough that it no longer has to go through emissions. A built C6 is about half the price and a good stall convertor is about a third of the price vs E4OD. I had already planned on having Tom Woods drive shafts made for it wether it had a E4OD or a C6 so thats no big deal. Just wondering what parts of the ABS a guy would have to remove? Also with the C6 I would be able install a B&M shifter, currently no one makes a console shifter for an E4OD....or atleast not that i'm aware of. Any input or help is always appreciated.
Old May 27, 2009 | 06:59 PM
Kemicalburns
well the entire abs pump and plumbing would need pulled. basicly running the brake setup from an 88-91 would work. be a good time to upgrade to an F350 booster though.
Dflynn926
Dec 6, 2016 12:43 PM
andy80
Apr 11, 2016 08:21 AM
Jetmech6
Feb 25, 2014 06:53 PM
tredizz52
Dec 1, 2010 12:51 AM
Shiny62
Sep 25, 2005 05:18 PM
