Sponsored by: Kumho
downsize on rims
Old May 25, 2009 | 12:45 PM
spin498's Avatar
spin498
downsize on rims
'02 Lariat F150 came stock with 17 " rims. I'm wondering if a)is it possible to go down to 15 " on aftermarket wheels and tires b) would it adversly effect handling/braking assuming whatever tire I go with has same final diameter as the 265/17's it's running now.
Old May 25, 2009 | 04:11 PM
johnboy427's Avatar
johnboy427
Will they fit over the calipers? That is most likely going to be your biggest issue.
-Johnboy
Old May 25, 2009 | 11:34 PM
85e150's Avatar
85e150
If the tires are the same diameter with 15s, it will wallow a bit more. Are 17s hard to find a tire for?
Old May 25, 2009 | 11:39 PM
johnboy427's Avatar
johnboy427
I think they are hard to find tires for and expensive my dad had an 03 FX4 and he had very limited options. I really don't think 15s will fit though his caliper was about a 1/2 inch away from the wheel, mabey if you ran some steel wheel instead of aluminum and they were not as thick but most likely not.
-Johnboy
Old May 26, 2009 | 01:20 PM
spin498's Avatar
spin498
Well pricing out BFG KO's in my neck of the woods, roughly $90 a tire difference in price, that's good enough. And they're mid range price tires.
If I go with something more expensive you're looking at $110 or more.
Old May 27, 2009 | 02:20 AM
aurgathor's Avatar
aurgathor
Nope. 15" is most certainly a no go.
Old May 27, 2009 | 05:29 AM
spin498's Avatar
spin498
I thought that 15's were standard on the base model, but I've found a page with the '02 specs that says they were 16". Oh well guess I need to wait another couple of months to save those extra pennies.
