2004 6.0 will not start need some HELP
Old May 25, 2009 | 11:05 AM
Digger Deep's Avatar
Digger Deep
I have a 2004 6.0 with 125,000 miles and it will not start. I have a edge programmer it came up with code P2623 Injector Control Pressure Regulator Circuit. I need some help and can i fix it my self and how much will the parts cost to fix the problem.
Thank,
Jeff
Old May 25, 2009 | 11:21 AM
BowTieHatr's Avatar
BowTieHatr
replace the ipr first. nothing else.
Old May 25, 2009 | 11:42 AM
Wyatt66f100's Avatar
Wyatt66f100
inspect your IPR wiring harness for chafing or rubbing. should have a heat shield around it. also 6.0L dont fire and wont fire unless the ICP sees 500 psi or more. so does it spit on start up? does it want to satrt is what im saying? tyr a long crank on it. if it pop and jumps like it wants to start id replace the IPR. could be stuck open not alowing high pressure oil to build up. if that doesnt fix it you could have a high pressure oil leak.
75Three90
Mar 12, 2016 05:37 PM
tbax46
Nov 28, 2015 07:13 PM
mookie2066
Nov 9, 2015 07:13 PM
tegangrable
Jul 23, 2014 10:44 PM
04 6.0L 250SD SC 4X4
Dec 27, 2003 12:51 PM
