Cab Mount Replacement Guide
Old May 25, 2009 | 09:07 PM
Diesel_Brad's Avatar
Diesel_Brad
yup. thts the sleave kit you need. May be cheaper from ford though
Old May 25, 2009 | 09:22 PM
FordF350Baby's Avatar
FordF350Baby
Okay cool, that is everything I need right, so I can destroy everything to get them out?
Old May 25, 2009 | 11:17 PM
goodB0Y's Avatar
goodB0Y
go for it...........
Old May 27, 2009 | 08:28 AM
waynaferd's Avatar
waynaferd
Yeah, don't bother trying to save anything
And I'm up in Lincoln, about 40 miles north of Bangor....
Old May 27, 2009 | 10:18 AM
FordF350Baby
Howcome this site has CHEVY advertisements on it?
Old May 27, 2009 | 12:45 PM
Diesel_Brad
https://www.ford-trucks.com/forums/853993-wth.html
Old May 27, 2009 | 01:46 PM
FordF350Baby
how stupid, if i wanted to see Chevy advertising I would be on a chevy forum, not a ford forum.
Old May 27, 2009 | 02:02 PM
Diesel_Brad
I'm sure one compary ownes several forums. that company just sells advertizing space. doesnt matter what brand
Old May 27, 2009 | 02:24 PM
McLeod's Avatar
McLeod
One guy used a holesaw just a little larger than the nut on the bottom in order to separate the nut from the bottom shell.
After removing the mount assembly from the perch, seperate the nut portion from the upper shell and then simply use a standard nut and washer in it's place.
I didn't need to go that extreme on mine. I was able to blast the units apart by beating on the bolt with a BFHammer.
Just make sure you remove the "interlock" between the upper and lower shells so you wont have to go there again.
And yes, the poly mounts do radiate just a little bit more road vibration into the cab, but it is minimal and not annoying.
Old Nov 15, 2009 | 02:28 PM
Red Cobra's Avatar
Red Cobra
I just did mine, and cut the rear bolt heads with a grinder, got lucky on the middle ones, and used a sawzall/grinder under the radiator support. I had to cut the middle bushings out, though, because of the sleeve/washer thingies built in.
The factory bushings have metal sleeves/washers, and my poly didn't come with any, and the stockers were either too rusted or too cut up to use.
I just got some 1/2 inch bolts, then had some sleeves made up to slide inside the replacement bushings so the bolts fit tight instead of floppin around inside the bushings.
I dunno if you can get just the sleeve/washers from ford or not, but it would be easier.
Anyway, its a major PITA, I'm glad its over, and won't ever do it again!!
i just did the same thing i cut the top of the rear cab bolts off thinking i would be able to hammer them through and they are not moving am i just not beating them hard enough or is there more threads inside the body mount! im hating life right now lol so any help would beseet! thanx
Old Jun 24, 2012 | 07:18 PM
WhitefishBoy64's Avatar
WhitefishBoy64
Howdy,
So i just removed my bushings. I had no idea how to and would have ended up spending hours and hours destroying them to get them off if it had not been for the idea of using an deep well impact socket and a jack. It took me more time to move my hydraulic jack than it did to cut those bad boys off with the Sawzall. i lifted up on them from below unit my wheels began to lift off the ground and i had tons of clearance to get the blade in there. Thanks for posting that idea... here are some pics to help explain
Pictures by Whitefishboy08 - Photobucket
Thanks,
WhitefishBoy64
Old Jun 24, 2012 | 07:24 PM
Diesel_Brad
Originally Posted by WhitefishBoy64
Howdy,
Thanks,
WhitefishBoy64
I dont get what you were pushing on. The mounts need to get PULLED apart,
Old Jun 25, 2012 | 01:12 AM
  #28
WhitefishBoy64
Howdy,
It is all one combined piece. There are steel bushings that run the length of the rubber. By compressing (pushing upwards) on the bottom rubber section, against the steel that the two halves are sandwiched around, the top section of rubber is pushed up slightly via the steel bushing inside of it. This allows for plenty of room to slide the sawzall in between the rubber and the fame and allows you to cut the steel bushing and the rubber that is holding the two halves together. After cutting though the steel bushing the entire cab mount will fall apart.
The part that i am pushing on is the welded nut on the bottom most part of the mount. if you get down and look up at it from underneath you can see it. On the drivers side you will need to remove the gas tank support strap, two bolts through the center frame support, and peel it back. I used a deep well socket and an extension straight onto the jack.
Thanks,
WhitefishBoy64
Old Jun 25, 2012 | 10:09 AM
  #29
Diesel_Brad
Ok. I follow what you did now, BUT you RUINED the steel bushing and they are about $50 a piece.
To pull the mounts apart.... all you need is
-3" diameter exhaust tubing(5" long)
-7/16 threaded rod (8-10" long)
-scrap angle iron from a nerf bar mount
1st unbolt one side(driver or passenger)
- loosen the other side(but do NOT remove the bolts)
- fashion a puller. Similar to this
-Slide the pipe over the bottom mount then some flat stock. And put the threaded rod thru the flat stock and thread into the nut on the bottom mount.
- Then tighten a nut against the flat stock. It will pull the lower mount from the upper.
-Once you have them separated, you need to remove the steel sleeve from the rubber bushing. Then slide the steel sleeve into the new poly bushing. and reassemble.
I still have the bed off my truck so I cannot judge if I need to reuse the factory shims. You may or may not
here is the bushing that came from the passenger side front cab mount. There is about 1/4" difference between the old/new. And the new ones are much more rigid, so they will not crush down like the OEM rubber ones
Old Jun 26, 2012 | 12:49 AM
  #30
WhitefishBoy64
Howdy,
Well for what i am doing i did not need to save the mounts. I am putting a 64 body on my frame and i am having to fabricate mounts that will use some of my 94 and some of the 64. I would spend the extra time and effort to pull them your way to save the bushings, if i was to reuse them, especially for $50. Here is a link to my project, i will be updating it one of these days.... when i have the time...
https://www.ford-trucks.com/forums/1...storation.html
Thanks,
WhitefishBoy64
