dana 44
Old Dec 20, 2000 | 01:25 PM
oz9609's Avatar
oz9609
dana 44
Old May 5, 2002 | 07:04 PM
tbolt 460's Avatar
tbolt 460
dana 44
is a Dana 44 front end ring and pinion the same for Ford and C***Y
Old May 5, 2002 | 11:39 PM
wayne_j's Avatar
wayne_j
dana 44
yep
Old May 6, 2002 | 05:58 AM
rabidranger's Avatar
rabidranger
dana 44
NO, not if it is reverse cut for the Ford.
Old May 6, 2002 | 10:31 PM
redranger1's Avatar
redranger1
dana 44
i am pretty sure that all of the ford front end axles are reverse cut. therefore they will not interchange with the chevies. but the ford dana 60 rear will interchange with the chevy dana 60 front. just some useless info.
-nathan
Old May 8, 2002 | 03:21 PM
jopey's Avatar
jopey
dana 44
Wayne your wrong.
the R&P for a ford D44 & D60 are reverse cut.
Chebby uses regular cut gears.
but the actual carriers are the same and will swap back and forth.
Old May 8, 2002 | 03:45 PM
bigoldblue's Avatar
bigoldblue
dana 44
and prior to 1978? dana 44 axles in ford weren't reverse cut. so in theory those should interchange
david
Old Jun 7, 2002 | 01:48 AM
Mr_N's Avatar
Mr_N
dana 44
>david
That is so wrong, is it a joke?
I'll pay you $10 if you can find a Dana 44 that is not a high pinion in any 70's F100 or F150. I've never seen on, ever.
Excluding Extenda cabs, and F250 up to 77.5.
Old Jun 7, 2002 | 05:15 AM
karljay's Avatar
karljay
dana 44
[updated:LAST EDITED ON 07-Jun-02 AT 06:18 AM (EST)]Are the "reverse cut" and "high pinion" the same? I thought the pre-77 had the "low pinion" and after that it was the "high pinion"
I guessed that the high pinion was a reverse cut and the low pinion was a standard cut.
After re-reading your post I noticed your excluding the F250 so that leaves me out.
Old Jun 7, 2002 | 09:03 AM
AZ4x4f150's Avatar
AZ4x4f150
dana 44
The high pinion was a reverse cut gear. But the carriers were the same. Chevy never used the high pinion setup only Ford. The TTB Dana 44 and solid Dana 44 carriers are interchangable but not the gears.
You could do it but it won't last long.
Old Jun 7, 2002 | 03:15 PM
tbolt 460's Avatar
tbolt 460
Post dana 44
the ring gear bolt pattern is different(chevy is smaller)and the inside dia. is smaller.Any one need a 4:11 r&p for a C***y?
Old Jun 7, 2002 | 10:09 PM
Mr_N's Avatar
Mr_N
dana 44
The correct name is "Reverse Spiral Gear Set", also known as High pinion, Revers Rotation and reverse cut. CHeck out Dana's Expert web page!
Old Jun 8, 2002 | 06:30 PM
alpo23's Avatar
alpo23
dana 44
>C***y?
:-X23 No,no,no......well, maybe, My DANA axle kit catalog lists the same part# for a C$#%Y Ring&Pinion assembly as the D-44 for an Early Bronco that still ran the low pinion gears. Same part# so how can it run a different bolt pattern than the Ford low pinion??????
Eric
Old Jun 8, 2002 | 06:44 PM
alpo23's Avatar
alpo23
dana 44
>"high pinion"
Karjay and all, here is the scoop on when Ford used the low pinion and the high pinion.
From 1959-1977 1/2 The F-250 used a Low-pinion D-44,
1977 1/2-1979 F-250 used Hi-pinion D-44.
From 1959-1965 the F-100 used the Low-pinion D-44.
From 1966-1979 the F-100 used a Hi-pinion D-44, Drums from '59 thru '75, discs from '76-on...
The Early Bronco from 1966-1971ish used the low pinion D-30
From 1971ish-1977 it used the Low-pinion D-44.
Big Bronco 1978-1979 used HI-pinion D-44
1974-1975 D-60 was closed knuckle and Low-pinion with Drum brakes. Same axle shafts as the HD Big-hub #3500 D-44.
1976-1977 D-60 was open Knuckle Low-pinion with Disc brakes,
different axle than HD D-44.
1978-1979 D-60 was open knuckle with Hi-pinion with discs.
( This is the Bomb )
Mr N., you're still holding out on when Dana went Hi-pinion. I assume it is '66 since I do have hard #'s to back it up to '67.
Eric
Old Jun 8, 2002 | 07:23 PM
tbolt 460's Avatar
tbolt 460
dana 44
Not only does the C***Y one have a smaller inside DIA.but it is thicker.If anyone wants a pic email me.
