Its on my 3rd brake light under tailgate but also did it to the trailer. I thought maybe it was the 3rd brake light but it was both. I tried it with my 7pin to 4pin plug in and the 4 pin. I thought maybe it was my trucks 4pin but it was both. Im thinking its something to do with my trailer hook ups on my truck. something grounding out etc.
definitely sounds like you have a short somewhere, was just trying to figure if the problem was your trucks wiring or the trailers, if it only seems to happen with one trailer, i would lean to that trailer, but if it happens when you plug any trailer in then it is more than likely a truck wiring issue! is there any water in the trailer light housings or any nicked wires you can see?
Im gonna hook up to a different trailer today and see if it does the same thing. I do have a small crack in my tail light and i have seen water in there im gonna pull it off and check it all out..
You may be on to something with seeing water in the tail light. Here is the thing. The four pin connector has, left turn signal, right turn signal, tail light and ground. There is no connection to the back up lights.
Any time the back-up light fuse blows is because it has a path to ground without any load, ie. lamp bulbs.
My question is what else does this fuse supply for a trailer? The seven pin connector has the same four supplies as above with the addition of battery charging, trailer breaks and perhaps back-up lamps. ah-ha.
So, when exactly does your fuse blow? When you first plug in the trailer? or when you turn on the lights? or when you apply the breaks? or when you put the truck into reverse?
Let's pin this down first. BTW, your not the first one to have this problem.
