Fault Codes, need help figuring it out
Old Dec 27, 2011 | 11:05 AM
ChristopherN's Avatar
ChristopherN
Hey i got a the Equus code reader. I get codes 33 C and 34 C. Both are saying the EGR is not closing properly/the circuit is not working. What steps do I need to take to fix this?
Old Dec 27, 2011 | 01:52 PM
ChristopherN
I did some pressure tests and the egr valve passed, however when I did the pressure test running, there was no change in the way engine ran, the valve did move as well, would this indicate a blocked line?
Old Dec 27, 2011 | 02:37 PM
Slip ford man's Avatar
Slip ford man
Try running this test Fuel Injection Technical Library » EGR Vacuum Regulator (EVR)
Old Dec 27, 2011 | 05:20 PM
ChristopherN
Where is the EVR located? Is that doohicky on top of the EGR?
I ended up replacing the EGR valve anyways since It's probably the original, and I had an Auto Zone gift card. While it helped, I still have some surging from time to time during idle.
Old Dec 27, 2011 | 05:26 PM
Slip ford man
Its near the coil
Old Dec 27, 2011 | 05:27 PM
ChristopherN
What coil?
Old Dec 27, 2011 | 05:56 PM
rla2005's Avatar
rla2005
It's the part labeled EVR:
Next to the ignition coil on the driver side of the engine.
Old Dec 27, 2011 | 06:36 PM
ChristopherN
I'll do some testing tomorrow when theirs more light and it's a bit warmer out, thanks for your help guys.
Old Dec 28, 2011 | 03:00 PM
ChristopherN
Did some vacuum testing and I found that I have only 1.37 in Hg (18.5 inches of water) on the EGR side, and 0 on the vacuum side. So, I have a vacuum leak somewhere. Where do I start looking?
Old Dec 28, 2011 | 03:33 PM
fonefiddy's Avatar
fonefiddy
The first place I would look is the vacuum reservoir. Notorius for rusting ot on the bottom. Then I would check the hard lines going to the egr, around the back of the intake .
Old Dec 28, 2011 | 04:16 PM
ChristopherN
Are they the cans on the left side of the engine behind the battery?
Old Dec 28, 2011 | 04:38 PM
Slip ford man
Yea that's it...inspect your whole vacuum system sticker on the hood, run the motor goose the throttle, you may hear the leak.
Old Dec 28, 2011 | 04:48 PM
ChristopherN
Well, I have this sucking noise during a cold start, is that part of it? Just curious.
Old Dec 29, 2011 | 11:36 AM
ChristopherN
Well, the coffee can thing was ok, no rust to be found, when I pulled the lines off there was an air noise, so it was hold vacuum. The lines are ok, no bad hoses, all hold pressure ok, would it be possible the vacuum thing on the intake manifold lines are mis-matched? But now would that cause issues....
Old Dec 29, 2011 | 01:03 PM
Slip ford man
Trace the EVR vacuum line to its source, remove it, check for vacuum at that fitting, check the hose real good, blow through it too.
