E4OD Fluid Change
Old Jun 7, 2002 | 04:13 PM
Ryan50hrl's Avatar
Ryan50hrl
E4OD Fluid Change
Old Jun 10, 2002 | 12:31 AM
JQ's Avatar
JQ
E4OD Fluid Change
I want to change over my E4OD from regular Mercon to a sythetic ATF. Does anyone know how to drain the existing fluid completely? How do I refill it? I do not what to use a trans fluid exchanger because I want to change the filter too.
Thanx...........JQ
Old Jun 10, 2002 | 06:05 AM
Ratsmoker's Avatar
Ratsmoker
E4OD Fluid Change
You can change the filter and use the flush machine. Do the flush first and then change the filter. It will take a little more fluid but you don't want to cycle all the old fluid through a new filter.
Old Jun 10, 2002 | 08:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
E4OD Fluid Change
Here is a link for a DIY fluid change:
http://www.ford-diesel.com/faq/1999faq/Maintenance-AutoT.htm
Mark
