View Poll Results: WHAT BATTERY FOR MY TRUCK
Group 34 no mods
0%
Group 65 change back to way should be
58.33%
Group 31T-5 1100 CCA
41.67%
Other
0%
Voters: 12. You may not vote on this poll
NEW battery sizes
Old May 24, 2009 | 07:12 PM
pintoches's Avatar
pintoches
NEW battery sizes
PO of my truck but a group 34 side post in my truck. the battery has gone bad. so Im thinking it time to update. should I go back to a group 65 also thinking about a group 31T-5 1100CCA. what do you all think.
Old May 24, 2009 | 09:35 PM
Blue Rebel's Avatar
Blue Rebel
I put a group 31 stud post into my old 95, and loved it. Could run my system for hours, key to acc, and not drain the batt.
Old May 24, 2009 | 09:36 PM
Jermafenser's Avatar
Jermafenser
I'd change it back to factory.
Motorcraft BXT-65-850. They last the longest.
Old May 24, 2009 | 09:37 PM
litlmeck's Avatar
litlmeck
If a 31 will fit and the $ is right then throw it in
Old May 24, 2009 | 10:17 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Can't go wrong with the proper sized walmart battery. I'm going on 7 years with mine.
Tim
Old May 25, 2009 | 12:23 AM
Dean88's Avatar
Dean88
I absolutely love interstate batteries. My demo derby car had an interstate on it when I got it, and the batt had been sitting the sun and other elements so long the green top is now white, but after putting it on a charger for all night, it held a charge and was able to turn over a motor so hot it ultimately set fire to the oil that was dripping out of the valve covers.
Old May 25, 2009 | 12:41 AM
snipAR-15's Avatar
snipAR-15
For what it is worth...
all the batteries are make by Johnson controls (interstate, costco, walmart, autozone, autolite, duralast, etc.)
Old May 25, 2009 | 01:48 AM
f250ssd's Avatar
f250ssd
Odyssey group 31. Make it fit.
Old May 25, 2009 | 08:53 AM
tseekins's Avatar
tseekins
That's funny. Why do some batteries seem to out last other brands? We are so brand loyal and never stop to think that there might be a common supplier.
Tim
Old May 25, 2009 | 09:15 AM
Dean88's Avatar
Dean88
Even if they have have the same supplier, I put it like this the 08 s'duty is nothing like the 70's Pinto fireball, and those are both Fords
Old May 25, 2009 | 12:32 PM
Jermafenser
Incorrect. There are SEVERAL.
Douglas, EverStart, Exide, etc.
Every battery has the manufacturer's code number on the battery and is the only sure way of identifying the manufacturer. MSDS can provide info.
Also, every private label has different specs than the others, even when they are from the same manufacturer.
Old May 25, 2009 | 12:34 PM
snipAR-15's Avatar
snipAR-15
Tim
That is a good question. Since all batteries can fail though, I look for the battery with the best warantee.
Old May 25, 2009 | 12:56 PM
snipAR-15's Avatar
snipAR-15
my mistake, I forgot about exide, but I did not know that douglas and everstart made their own batteries. In fact, Im quite sure that everstart in made by johnson controls as well. I have one in my truck now. IT says made by johnson controls.
Old May 25, 2009 | 01:14 PM
ottawaguy's Avatar
ottawaguy
Ditto that!!
Old May 25, 2009 | 07:22 PM
Jermafenser
I think you're right. I think EverStart is Wal-Mart's own private label battery? I don't recall now. Way toooo many private labels! But Exide is its own company, correct.
