Automatic locking hubs
Old May 24, 2009 | 09:12 AM
Green Giant's Avatar
Green Giant
I was servicing my auto hubs and found one to be ratcheting, not fully disengaging. I am convinced that a washer type shim, can be made from shim stock and added to the hub to create the needed clearance to salvage the hub. Has anyone tried such an unorthodox repair?
Old May 24, 2009 | 09:45 AM
vettdvr's Avatar
vettdvr
No but I followed guzzle's directions to clean and service.
I also sprayed silicon lub on the outer face groove of the auto/man end and worled the silicon into the hub. This freed up the selector to make it easier to operate w/o damage to the internal rubber parts.
Old May 24, 2009 | 11:39 AM
Green Giant
I too followed Guzzle's. I didn't have as much success with the silicone. I still have to use duck bill vise grips on the selector, but I can now rotate it. How did you work the silicone lube into the hub? I only sprayed it on and let it sit vertically for 30 minutes.
Old May 24, 2009 | 10:37 PM
EXv10's Avatar
EXv10
Get some non spray if they make it or spray some in a bowl and immerse the end in it about 3/4" deep and let it sit overnight. Or use the red tube it should come with and spray around the crack while wrapping the end of the tube/straw with something soft like tissue paper to force the fluid into it.
Old May 25, 2009 | 12:43 AM
Green Giant
Thanks
Thanks for the help.
Old May 25, 2009 | 10:54 AM
vettdvr's Avatar
vettdvr
Good idea I didn't think about using a bowl.
I did spray it on the groove and let it leak into the end of the hub. Then rotated the hub so the lubricant would coat the inside. My auto/man would move but very difficult. After a while it made it to where needed and freed up.
I was tempted. to drill a 1/16 hole in the hub to squirt it directly in the hold then insert a small ?? 2x56 screw to plug the hole. But didn't do it.
Old May 25, 2009 | 12:32 PM
EXv10's Avatar
EXv10
I think there is something on guzzles site obout drilling a hole.
Old May 25, 2009 | 01:05 PM
vettdvr's Avatar
vettdvr
I must have missed that, I didn't see it.
Old May 25, 2009 | 01:12 PM
EXv10's Avatar
EXv10
Sorry, I saw it somewhere in there.
Old May 26, 2009 | 05:05 AM
Green Giant
I think Guzzles mentioned that for complete disassembly of the manual selector.
Old May 26, 2009 | 07:43 AM
vettdvr's Avatar
vettdvr
You are correct he does mention drilling a hole. However this is a new addition in the site as it was not there 18 months ago when I did my hubs.
I think a small hole as I mentioned might work but I would use a screw vs the epoxy he mentioned. Fortunately I as able to work enough silicon lube into the hub through the end slot.
cchev
Jul 5, 2012 01:13 PM
Capt.Schenk
Jul 1, 2009 12:10 PM
woodbutcher2
1978 - 1996 Big Bronco
Dec 20, 2004 03:41 AM
MarkVZ
Feb 9, 2004 03:26 PM
