AOD Transmission
Old May 24, 2009 | 08:53 AM
reconnick's Avatar
reconnick
AOD Transmission
I hae just installed a AOD Trans from a 1987 Lincoln Town Car into my 1979 F100 XLT (302 C.I.). The tranny worked perfect in the Town Car. I replaced the throttle valve, filter and fluild. I can't get the tranny to shift into 3rd. The throttle valve pressure is correct at idle and fast rev. I installed a new kick down cable from Summit. The kickdown cable is adjusted correctly. Anyone got any ideas?
Old May 25, 2009 | 10:44 PM
jk080's Avatar
jk080
Transmission Rebuilder
Why did you replace the valve?
I think the problem would be with the valve body.
