Need help leveling kit 09 f150
Old May 24, 2009 | 07:39 AM
kdean2608's Avatar
kdean2608
There are simply too many designs and choices for a simple 2" leveling kit for my new 09 F150 4x4. I am sure this has been debated, but can anyone tell me the differences between using coil over spring, spacers, plastic v. metal etc? Who makes the best kit that does not change smooth ride quality? airspring, ready lift, sky jacker, daystar? Thanks for the help.
Old May 24, 2009 | 12:52 PM
silver05fx4's Avatar
silver05fx4
well i would say a all steal spacer is the best, it will not change any ride quality and go to ebay look for hell bent or autospring their the best priced and most used
Old May 24, 2009 | 01:58 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Autosprings FTW
all steel construction, and they were the first on the market for the 04-08 trucks.
Above Spacer:
you remove your front coil-over, bolt the 2" spacer ontop of it, then re-install to the truck
has NO EFFECT ON RIDE. just gives you a few inches of altitude up front
Inside Coil-over:
remove coil-over from truck
dis-assemble the coil-over
insert the 2" plastic puck
re-assemble and install
This does change your ride quality. The plastic puck changed the spring pre-load...typically makes the ride harsher
parker245
2009 - 2014 F150
May 7, 2012 05:33 PM
Hlbk3
2009 - 2014 F150
Dec 1, 2011 01:02 PM
Myf350sd
2009 - 2014 F150
17
Aug 29, 2010 11:53 PM
nathan09
2004 - 2008 F150
16
Dec 16, 2008 01:54 AM
