Please decode this vin
Old May 23, 2009 | 12:12 PM
zenmaster's Avatar
zenmaster
Hi Folks,
I have a 1967 Mercury M100 pickup. The vin tag located on the firewall says:
F10YCA47463
131 M8 2D 4
The transmission casting says:
T-18-1
N1
W. O. DIV (the "O" may be a "G" or a "Q")
The tag on the rear differential says:
43-13
3.31
There is no vin plate on the door, but the 2 rivet holes are still there. I looked on the top of the frame rail on the passenger side adjacent to the alternator, but found nothing.
I did find a paper tag under my bench seat. It reads:
C7TB FRT. BACK
8164700-A
Thanks for all your help!
John
Old May 23, 2009 | 02:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by zenmaster
Hi Folks,
F10YCA47463
131 M8 2D 4
T-18-1
N1
43-13
3.31
C7TB FRT. BACK
8164700-A
John
F10 = F100 2WD
Y = 352 2V
C = Oakville, Ontario Canada Assembly Plant
A47463 = 1967, Assembled November 1966.
131" Wheelbase
MB: M = Wimbledon White / B = Frost Turquoise
2D 4: 2D = Medium Blue Crush Vinyl & Medium Blue Bar Pattern Vinyl / 4 = Bench Seat.
W-O (G) DIV: Warner Gear Division = Borg Warner T-18 4 Speed Manual Transmission.
3.31-1 rear axle ratio: Not listed for 1964/72 F100's. The center section could have been swapped in from a passenger car which was available with 3.31-1. Or the ratio may be Canada only.
C7TB-8164700-A = FoMoCo ID number for the seat frame itself.
Old May 24, 2009 | 12:45 AM
zenmaster's Avatar
zenmaster
Bill,
Thanks so much for your help!
I appreciate you taking the time.
Thanks,
John
frank_65
1947 and Older Ford Trucks
13
Feb 12, 2022 09:55 AM
USMC0351fordtruckin
24
Jul 24, 2013 07:05 PM
TKONO
Mar 25, 2002 08:13 AM
greentruck
Feb 24, 2001 11:05 AM
