Sterling semi float rearend slop
Old Jun 8, 2002 | 06:38 PM
brett_d's Avatar
brett_d
What is the right way to cure rear end slop. I have about an inch of overall slop (by turning the drive line it move about an inch from side to side until the gears bind). Is this usually caused by the ring/pinion or the spider gears..
Thank you in advance
Old Jun 9, 2002 | 09:40 PM
FortyFords's Avatar
FortyFords
This is an accumulative situation usually.
Backlash can be a result of the following
Ring an pinon gears
plus
spider gears
plus
axle splines
you would most definitely have to look in side to see
Rich
Ford Trucks Built Tough!
Not like all the rest!
Old Jun 12, 2002 | 04:56 PM
DIFFMASTER's Avatar
DIFFMASTER
The Sterling diff is built with a generous amount of backlash, that is the way the gear set is designed. How many miles are on the diff, do you tow with it? What size tires? The other common thing with this diff is they hammer out the splines in the yoke, causing excessive rotation.
Old Jun 18, 2002 | 10:36 PM
brett_d's Avatar
brett_d
It has 135k on it right now. It has 33" tires and I do about 20% towing and 80% freeway. The "clunk" just gets to me after awhile and was wondering how to get rid of it besides the old CHEBY fix, SAWDUST......
Old Jun 21, 2002 | 07:14 PM
DIFFMASTER's Avatar
DIFFMASTER
I would seek out a reputable Differential shop, let them do a diff service, check rotation in degrees, check backlash, check for worn splines in the yoke, check for side to side in the carrier, check for worn side gears and axles. Please post your results if you decide to have it checked out, that's the first step.
Old Jun 21, 2002 | 07:18 PM
DIFFMASTER's Avatar
DIFFMASTER
rews2
Mar 27, 2014 06:25 PM
JayzDaddy
Jun 21, 2012 11:07 AM
i-w
Oct 12, 2009 04:08 PM
mrlightrail
13
Sep 5, 2007 08:47 AM
mdjohnson
Jan 15, 2006 12:22 PM
