Need some help on leveling kits.
Old May 22, 2009 | 04:46 PM
caprang's Avatar
caprang
Im trying to find out what works and what doesnt on the 09. For reference this is for a 4x4. I see some people list 2004-2009 while other people list 2009 separately. I have also seen them as cheap as $60 and as high as $250. Im confused so I am turning to FTE to see what everyone is using in the real world rather than just reading advertisements.
I appreciate as much info as you can provide. Thanks!!!
Old May 22, 2009 | 05:15 PM
senix's Avatar
senix
I highly recommend skyjacker, had in on a previous truck. Comes with all the brakets and everything.
Should also get a 1" add a leaf for the rear. This will make it level. 2 1/2" leveling kits does the trick.
Old May 22, 2009 | 07:01 PM
caprang's Avatar
caprang
Do you know if there is a difference between the 04-08 F150 and the 09 F150 leveling kit?
Old May 22, 2009 | 07:16 PM
senix's Avatar
senix
On skyjacker's website they list everything from a 2" up to 6" for the 2004. For 2009 they only list 6" lifts.
Product Search - Skyjacker
Old May 22, 2009 | 07:17 PM
silver05fx4's Avatar
silver05fx4
they will all work but ford did make in harder to reinstall the shock
Old May 22, 2009 | 07:41 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Leveling kit fit the 2004-2009 truck
the only front suspension difference between your 2009 and a 04-08 is the lower control arm...which is steel now, vice the older ones with aluminum.
I suggest you get a 2" leveling kit...only get the 2.5" kit if you intend to install a AAL out back.
btw, Skyjacker and Readylift kits for the F-150 are a rip-off. You can get the same effect for well under 1/2 the price of those kits.
$60-70 shipped for a leveling kit is the going price
Pearson4
2009 - 2014 F150
Nov 24, 2014 01:25 PM
jgoldwood
2009 - 2014 F150
Nov 15, 2014 09:36 AM
Snowking
Jun 16, 2013 08:51 AM
Daytona72
6.4L Power Stroke Diesel
51
Dec 3, 2009 08:26 PM
aortizexcursion
2009 - 2014 F150
50
Aug 7, 2009 10:49 AM
