300 I6 pulling power
Old May 22, 2009 | 03:18 PM
6CylBill's Avatar
6CylBill
Hi guys
Just pulled my dad's Elky on a car hauler (pics later). The combo weighed in around 5,500 lbs. I went around the block a few times, I didn't go far. All I ever heard was how strong a pulling motor the 300 is. I was disapointed in how my truck handled, but I've never towed anything before (asides from pulling stuck trucks out of the mud).
I have the e40d and 4.11 gear ratio with 31'' tires. I never went past 2,000 rpm to get it going but it felt hard to get going. Is this normal?
Just wondering what "normal" feels like pulling a 6,000 lb load. I know my owner's manual says an F-250 with the 4.10 gear / 300 I6 is rated to two 11,000 lbs. I would not want to tow that much in my truck after pulling 6,000 lbs.
Just wanting thoughts and opinions from you guys. My first time pulling / backing a trailer with a full size car (I did pretty dang good, too!)
-Bill
Ps. Once I got the load moving, it didn't feel bad at all. I'm just wondering if it's supposed to feel so hard to get going. On a side note, my truck sounded just like a dump truck. Sounded really cool
Old May 22, 2009 | 03:52 PM
lew52's Avatar
lew52
Bill you just need a 302 !!!!!! LOL.... The 300 should pull the load good with 411s ?? Lew
Old May 22, 2009 | 04:11 PM
6CylBill's Avatar
6CylBill
Lew, I'm not sure a 302 would have done much better. I never went past 2Grand.
Some pictures, just for grins
Old May 22, 2009 | 04:29 PM
murph77's Avatar
murph77
Originally Posted by 6CylBill
Hi guys
I suspect this may be an automatic trans thing.
What's the stall in you torque converter?
It may be letting that little turtle rev too high into it's power band before it engages.
Just my guess.
For this reason, I've never liked the 300 paired up with a slushbox.
Sure, you take a little life off the clutch slipping it at 1500 rpm,
but you're in control of where the drive train engages.
Murph.
Old May 22, 2009 | 04:32 PM
lew52's Avatar
lew52
Looks nice !! Im sure the 302 wouldn't do any better . The 300 at 2000 is right in its TQ range . It should haul that with no problem !!
Old May 22, 2009 | 04:52 PM
6CylBill's Avatar
6CylBill
Just my guess.
Murph.
Murph, I appreciate your time. I don't even know what a torque converter does so I couldn't tell you. It's all stock minus the gear ratio and exhaust. If what you're saying is correct it does make sense because I felt like I had to rev it to get it going. I just always thought the 300 was such a good puller off the line. I think what I was expecting was a smooth as silk, easy off the line TAKE OFF. Which it really wasn't bad.. It just felt a lot heavier to 6,000 lbs to me (although I've never pulled before).
Edit: Does it help to know my truck came with a pulling package with a 3.08 gear ratio??
Thanks Lew. Notice how the Chevy is the only one who has to ride.. Our Uhaul is a Big Block powered Ford that doesn't like to rev past 3,000 rpm. It's a puller alright!
Old May 22, 2009 | 05:36 PM
murph77's Avatar
murph77
Bill, picture this.
A fan running, and directly in front of it, is a fan that is off.
The running fan will spin the fans blades that are directly in front of it. See?
Your stall is like the resistance of that fan that is off.
How fast must that running fan blow the air to spin the fan that is in front of it.
In the case of your trans, how fast does your engine need to spin
to spit trans fluid through that "second fan" to get it spinning.
That "second fan" is attached to your drive train.
Once you get that to spin, your wheels turn. Make sense?
Your torque converter has a "stall" number.
The stall number is the rpm your engine must reach before
your torque converter will engage and transfer power to the rear wheels.
It's sorta what you can do by working the clutch.
The main difference is that you are in charge...
not some dumb junky mechanical thing.
You might be able to tell that I am biased.
As far as what stall Ford used on your trans, I dunno.
Hope this helps your understanding,
Murph.
P.S. Knowing is half the battle.... Go Joe!
Old May 22, 2009 | 06:27 PM
6CylBill's Avatar
6CylBill
Thanks a lot Murph!
Maybe my truck didn't do as "bad" as I originally thought. The load was at least 6,000 now that I think about it.
Old May 22, 2009 | 06:39 PM
91Bronc300's Avatar
91Bronc300
Murph is right. The fact that you had to rev it to get the load moving is simply the nature of the beast with an automatic setup. Not an failing on the part of your engine.
The impeller (the part of a TC connected to the crank) has to accelerate ATF and slam it into the turbine (part splined to tranny input shaft). It's a fluid imparting it's inertial energy to the turbine that moves the truck. Not a mechanical connection like in a manual. If your turbine has a much greater resistance to turn (like towing) it takes much more inertial transfer from the fluid to get that turbine moving. And the only way to do that is to accelerate the impeller (crank speed) more so that the ATF gets slammed into the turbine harder and harder and finally gets it moving. Even a big old 460 with an automatic has to rev up more than normal to get a trailer moving. It's the slipping of fluid in the TC and not the engine being a pansy.
Old May 22, 2009 | 07:00 PM
6CylBill's Avatar
6CylBill
Thanks for the info! It all makes sense to me now. This is why I had no issues pulling the trailer once I got it moving. My idle speed was normal; I thought that was strange considering my truck felt so sluggish coming off a stop sign.
Yeah, I expected IMMIDIATE power off of idle (which I did, when it came to backing it in the garage, super slow speed. I could tell the low end power was coming into play here.)
I never knew there would be that much difference by just having an automatic. I mean, I'm sure I could have launched harder, but I was pulling 6,000 lbs; putting the pedal to the floor is not a good idea in this situation.
Old May 22, 2009 | 07:22 PM
murph77's Avatar
murph77
I'm prepared to take some flack for this statement,
I just hate slushboxes. Sorry.
Murph.
Old May 22, 2009 | 07:26 PM
6CylBill's Avatar
6CylBill
Murph.
Ford should have put ZF's in the F-150's instead of the M50D.
Slushboxes are good for trucks that don't tow.
Old May 22, 2009 | 07:43 PM
91Bronc300's Avatar
91Bronc300
I agree that ZF's should have gone in everything and those mazda transmissions should never have existed.
Although I will say, people who only drive manuals because they just don't like slushboxes are control freaks
(your official flak, Murph )
Old May 22, 2009 | 07:48 PM
6CylBill's Avatar
6CylBill
Ha ha.. Hey, I would have bought my truck over again in a minute. She's been a good little rig for me. I'm disapointed in how it takes off with a heavy load, but now that I know it's normal I don't really care.
Sure can't beat the sound ole' betsy was giving me though. Posessed Dump Truck
Old May 22, 2009 | 08:02 PM
murph77's Avatar
murph77
Hmmmmm...
Somehow I want to agree and disagree at the same time.
Wait, I'm not in control anymore... WHAT THE?!......
