Why an additional trans filter?
Old May 22, 2009 | 01:43 AM
Mulepick's Avatar
Mulepick
After receiving my truck back from having about $5k worth of warranty work done to engine and trans, I noticed that the dealer spliced an inline filter into the return side of the trans fluid between the cooler and the existing filter. It's a Ford filter and I'm wondering what purpose it serves that wasn't being served previously and what its periodicity for replacement might be.
Any ideas?
Tks,
Bob
Old May 22, 2009 | 02:12 AM
jmaskew's Avatar
jmaskew
Which dealer in town did you go to?
Old May 22, 2009 | 02:54 AM
Mulepick's Avatar
Mulepick
The same one I sent you to...
Ford Country.
Old May 22, 2009 | 06:03 AM
Rob.D's Avatar
Rob.D
At 30,000 miles I plan on upgrading to the 08 pan and 08 internal filter vs. the screen on my 06
Old May 22, 2009 | 08:07 AM
ljutic ss's Avatar
ljutic ss
I have that filter on my other truck (1989 IDI) with a Motorcraft rebuilt C6 trans. Thats the only way they will warranty the trans. Sounds like your added on filter was an overkill and a waste of money. You already have a canister filter setup. Thats an extra filter you have to replace now.
Old May 22, 2009 | 09:01 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
The filter they added is an in-line (not by-pass) filter which is made by Magnefine company.
Ford uses these little filters on most/all rebuilt tranny's and if something is suspected. There is a TSB on this issue and the filter is part of the rebuild kit.
Many also use this same filter on the p/s fluid systems.
It is a great filter and has a by-pass pressure relief valve in it. The filter has a magnet in it as well so it is catching ferous metal particals on the megnet and the paper filter is catching the rest of the stuff.
Your dealer did a good thing for you and the filters only cost $15.00 on-line if you wish to continue using them.
Check out the thread below. It relates to p/s fluid but is this the filter that was installed?
https://www.ford-trucks.com/forums/8...ing-flush.html
Good luck,
Old May 22, 2009 | 08:40 PM
Mulepick's Avatar
Mulepick
I've used Magnafine inline filters before on other vehicles. This is a ford badged filter that may do the same thing. Part number is 2w4p7b155bc:
http://img507.imageshack.us/img507/4623/p5220001.jpg
Bob
flipper612
33
Aug 4, 2019 05:41 PM
caskillet
Oct 19, 2014 05:59 PM
Donkey BBQ
18
Oct 18, 2013 04:36 AM
TEMiller
6.4L Power Stroke Diesel
47
Jan 2, 2013 08:07 PM
KC92F150
1978 - 1996 Big Bronco
Nov 13, 2010 10:47 PM
