Hey y'all. I was wondering if anyone knows off the top of their head what hubcaps will fit my 1965 F100 2 wheel drive stock wheels? What options are available that will "just fit" and how will I know if a certain cap will fit or not?
Hey y'all. I was wondering if anyone knows off the top of their head what hubcaps will fit my 1965 F100 2 wheel drive stock wheels? What options are available that will "just fit" and how will I know if a certain cap will fit or not? Thanks, SKY
It all depends on which wheels you have, as to which hubcaps will fit.
Some 1965's use hubcaps that snap onto tabs or clips, inside the center of the wheel.
These caps (C3TZ1130A) are 9 1/2" in diameter and have been reproduced in stainless steel, which all the Custom Cabs came with.
The Standard Cabs used two painted versions of this same hubcap.
Some 1965's use hubcaps that snap onto tabs outside the center of the wheel. These caps are 10 1/4" in diameter.
The stainless version of this cap used on Custom Cabs is the same as 1964 Galaxies, the two painted versions of this same hubcap are F100 only.
These hubcaps, AFAIK, are not reproduced.
To see what these stainless hubcaps look like, FTE member Customcab (Mitch) has a set on his truck, which is pictured in his gallery.
