Sponsored by: Real Truck
"Plug" story (or not)
Old May 21, 2009 | 11:10 PM
MikeMcCasland's Avatar
MikeMcCasland
I just finished looking at this TSB. It appears this spark plug issue only applies to 3V motors? I have an 04 6.8L do I have anything to worry about in terms of breaking plugs or am I in the clear?
Old May 22, 2009 | 12:03 AM
EXv10's Avatar
EXv10
You are in the clear. Just don't put them in too tight.
Old May 22, 2009 | 12:16 AM
EXv10's Avatar
EXv10
Originally Posted by DAVE67FD
EXv10,
I think your missing the point. With the plug in the head and the engine at full operating temperature the tolerance between the plug and head is at it's tightest thus making the already bad plug design (in a bad head design) more likely to have problems on removal.
This is why Ford specifically states not to remove the plugs from a hot engine.
Here is the TSB. See the first "Caution" note on the first page. This is the same procedure Ford follows on removal.
http://www.wfservices.biz/TSB%20Ford...%20removal.pdf
That just says it can't be a warm or hot engine and nothing about expansion. I still say it is the heat that increases the friction between the plug and the head. Heat plays a role in friction coefficiency.
Old May 22, 2009 | 12:30 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Coefficient of expansion in (10-6 in/in/degrees F) (that's 10 to the minus-6 in/in/degrees F)
Aluminum: 12.3
Steel: 7.3
This means that a steel fastener surrounded by aluminum will not expand as fast as the aluminum. Also, even if the materials were the same, say steel and steel, a fastener will not expand as much as the hole it's in.
That doesn't mean I'm condoning removing plugs on a warm engine.
Conversely, the threads in the warm head (aluminum) expand more than the steel plug, so when you're trying to remove the plug, you may damage the threads because the threads are pulling the tip of the plug that's dirty, and the threads are somewhat larger than the plug is. The tighter the threads, the less likely you will strip them trying to get the plug out. But then, you risk leaving the tip in there.
An earlier version of that TSB (or another one) said to do it on a warm engine. I guess too many techs were stripping the threads so they figured they'd just do it cold and the tip would separate instead.
Old May 23, 2009 | 12:26 PM
DAVE67FD's Avatar
DAVE67FD
Krewat,
Thank you
Old May 23, 2009 | 01:01 PM
EXv10's Avatar
EXv10
Actually, I don't think it makes any difference if it is warm or cold. I think somebody didn't break any plugs one day when it was cold so that circle was the "cold theory" bunch.
Action410
Modular V8 (4.6L, 5.4L)
Mar 29, 2016 10:15 AM
dadsutton1
2004 - 2008 F150
Oct 15, 2015 08:53 PM
speakerfritz
Mar 24, 2015 04:59 PM
Mcdanbee
Apr 13, 2011 08:20 PM
rprhyno
2004 - 2008 F150
23
May 30, 2007 06:42 PM
