Clutch problem, help please!
Old May 20, 2009 | 09:40 PM
IDPisan's Avatar
IDPisan
My clutch pedal was starting to feel soft and it took more throw in the pedal to get it to disengage. I had the same problem a couple of years ago, replaced the master and slave with the pre bled unit from Ford and fixed it. So thinking that I had the same problem I got another master and slave unit from Ford put her in and got her all put back together and now the pedal will only go half way down. Not far enough that I can't even start it. I took the slave out, was able to push the clutch in and get it started, so I know the master is not malfunctioning. put the slave back in and the pedal still only goes half way. Am I missing something ?
Old May 20, 2009 | 10:10 PM
robs01f250's Avatar
robs01f250
I havent ever heard of anything like this. Subscribing
Old May 20, 2009 | 10:20 PM
duck fan's Avatar
duck fan
Because racetruck
TRy bleeding the slave cylinder. Sounds like air in the line.
Old May 20, 2009 | 10:29 PM
IDPisan's Avatar
IDPisan
It is the Ford all in one pre bled unit that I just put in.
Old May 21, 2009 | 07:08 AM
IDPisan's Avatar
IDPisan
Anyone? bump.
Old May 21, 2009 | 10:08 AM
IDPisan's Avatar
IDPisan
Bump, anyone?
Old May 21, 2009 | 10:38 AM
superduty4x4's Avatar
superduty4x4
Could be Ford didn't bleed it properly? IDK man... hopefully you get it figured out.
