300 wont start
Old May 20, 2009 | 08:41 PM
150ford's Avatar
150ford
300 wont start
Ok guys a friend off mine bought a pretty bad looking old 9O f150. The engine cranks but will not start. Were thinking its an ignition issue. Do these have an ignition module somewhere. Thinking its bad. Or the coil is bad. Thoughts an input guys. Thanks for any help. Oh BTW can the module an coil be tested to see if there bad.? Thanks again.
Old May 20, 2009 | 08:49 PM
cooney89's Avatar
cooney89
the first thing i would do is check for spark. if no spark i would first check for power at the coil.if you have power there then i would remove the cap and turn it over and make sure that the rotor is spinning because they are know to shear the pin off. if it spins then if look on the distributor itself there is a plug that plugs into the ignition control module which is plugged into the distributor and is held on by two 7/32 bolts. you can take it to discount auto parts and they can test it to see if its good. if not that then change your coil.
Old May 20, 2009 | 08:56 PM
150ford's Avatar
150ford
Thanks for the info. Never even thought about the rotor not turning will check that out. Theres no spark we determined that.
h-m
Feb 25, 2013 03:02 PM
kgross
Jun 11, 2008 02:04 PM
mudder460
Feb 5, 2008 02:09 PM
deanfulmer
21
Mar 8, 2005 07:52 PM
