Plow
Old May 20, 2009 | 08:14 PM
1977 F250 4x4's Avatar
1977 F250 4x4
Plow
I see a fair number of dentsides behind barns and houses in my area some of them still have snow plows on although they have not moved in some time. I could really use one of those plows.
I don't want to drag home one those trucks to discover the plow won't fit on mine.
I have a 1977 F250 vin is F26SLY52299 build date April 1977
Does anybody know what year truck I should look for?
Old May 21, 2009 | 08:39 AM
psd350psd's Avatar
psd350psd
plow application
My understanding is the 73-77's have different mounts than the 77.5-79's. I think you have a 77.5 but someone correct me if I'm wrong. If your trucks aren't the same height off the ground, you may run into fabrication issues with the plow. If you buy a truck that sits and looks just like yours, you should be fine. Depends how much you like to weld...
Old May 21, 2009 | 01:22 PM
Jermafenser's Avatar
Jermafenser
Your '77 is a "late" truck so to speak.
You want to look for one from 1978/79 F-series.
Old May 23, 2009 | 08:41 PM
lostinfords's Avatar
lostinfords
I am taking this off of my '78 Bronco and am not going to need it, also have a set up on a 78 crew cab that is coming off
Old May 24, 2009 | 08:57 AM
1977 F250 4x4
Thanks
Thanks for responses I'll keep an eye out for '78 '79 then.
Old May 24, 2009 | 09:30 AM
fordjeep's Avatar
fordjeep
I know about Fisher...
Not sure about the other brands, but Fisher made push plates (the part that is different and mounts to a specific vehicles frame) for the 77.5-79. I got them from a friend and it took minor mods (if you can cut and weld) to make it fit my 69 F250. The did not make an push plates specifically for any years older than the 77.5-79 to my knowledge.
You can still find these plates with some diligence on ebay or craigslist and may even be able to find them new somewhere if you call all around the country to Fisher dealers. Many of them still have them buried in warehouse somewhere. If I recall, there was a large east coast dealer that still had several sets - maybe in Maine, Vermont, or Mass - don't remember. Once you have the plates, then you can pretty much use any of the older conventional Fisher plows you find.
Also, do yourself a favor and get one with an electric pump. I have the manual pump that runs off a belt to the crankshaft, but while functional, there isn't enough power to raise it quickly at idle & reving the motor to get the plow to move sucks. It's still functional, but definitely inferior to an electic pump.
Old May 24, 2009 | 01:19 PM
1977 F250 4x4
Good stuff
That was full of good info. Alright Fischer not seen one of those most of them I have seen have been yellow Meyer I was told.
Old May 24, 2009 | 02:34 PM
76f350spercamprspeal's Avatar
Are They by any chance the plows are like this?
http://i684.photobucket.com/albums/v.../Ads0001-1.jpg
http://i684.photobucket.com/albums/v...ls/Ads0003.jpg
madame_toussleau
1997 - 2003 F150
Nov 28, 2012 09:15 AM
Ford SD
Sep 18, 2012 10:37 AM
1977f150xlt
16
Oct 9, 2009 01:18 AM
snapshot
Aug 16, 2009 07:32 AM
zman300
May 4, 2009 11:23 AM
