Sponsored by: Real Truck
75 PSI Oh My
Old May 21, 2009 | 08:35 AM
Tom's Avatar
Tom
I probably should say this again...
DO NOT PUT 75 PSI IN THOSE TIRES!!! Fill 'em right to 44 and run them as long as absolutely necessary... Those tires are probably rated to about 2000 lbs/tire, as opposed to 3,000 lbs/tire...
For the rears this should get you by, but the front axle is nearly 5,000 lbs EMPTY, so they are overloaded up front...best to replace all 4 ASAP...and smack the clown that put those tires on your truck!
Old May 21, 2009 | 01:15 PM
busflyer's Avatar
busflyer
I've been looking online for prices so as to replace them when I get back home. Like was said earlier, I guess I'll try and sell them to offset the cost. I've got an exploreer as well but I can't remember what size skins it has on it. Thanks for "Lookin' out for me", I appreciate it. First super duty and first diesel so more questions to follow for sure.
Eric
Old May 21, 2009 | 01:40 PM
Downriver Thunder's Avatar
Downriver Thunder
If I were you I'd be looking to get new tires asap. From 05 on these trucks had the death wobble. I would not chance having mediocre tires on there, you're toying with your life and the lives of your passengers if you lose it.
Old May 21, 2009 | 02:48 PM
DAVE67FD's Avatar
DAVE67FD
Many owners purchase other than "E" rated tires for the SD's. If your truck never sees a load than they may be "capable" depending on their actual load range. By law and for safety reasons (as previously stated) the OEM rating should be followed. Some Tire shops will refuse to put other than what is specified on the truck. The tires you have on it may be "technically" adequate for your intended purpose but be aware. Check the actual load of the tire and don't exceede it.
Old May 21, 2009 | 03:34 PM
Vijay's Avatar
Vijay
Originally Posted by Furian
Do you have E rated tires on your truck?
Yes, they are...
Old May 21, 2009 | 05:53 PM
Furian's Avatar
Furian
You Keep What You Kill
Originally Posted by Vijay
Yes, they are...
My question was directed to the OP... I figured that you had E rated tires you big duelly! Just kidding!
