No Power
Old 05-20-2009, 04:51 PM
Randy2631's Avatar
Randy2631
Randy2631 is offline
No Power
Im lost so i hope someone can help me. I have a 1986 F150 with a 4.9L six. i was changing my starter solenoid monday and after i put it on, nothing worked. it acted like there was no battery. went back to autozone and found out they gave me the wrong one. i got the right one and put it on but still nothing. i tried changing both battery cables and still nothing.
im sure its blown fuse or a short but i dont know where it could be. all the fuses in the fuse box look fine.
Old 05-20-2009, 08:52 PM
86bigred's Avatar
86bigred
86bigred is offline
did you put the smaller wires on the battery side of the relay.these are the ones that power every thing,and charge your battery.
Old 05-20-2009, 09:22 PM
Big Ben's Avatar
Big Ben
Big Ben is offline
Check and see if you have any bad fuseable links as well.
Old 05-21-2009, 12:57 AM
hittman1422's Avatar
hittman1422
hittman1422 is offline
hey big ben you're a supporter now!! thats great!!! was kinda worried a bad start drove you off... truely glad to see you're pulling your weight and sticking around!!!
-sorry for jacking the thread
Old 05-21-2009, 05:48 AM
Big Ben's Avatar
Big Ben
Big Ben is offline
I am not going to let a little disagreement push me away.
Old 05-21-2009, 11:48 AM
hittman1422
glad to hear it!
Old 07-02-2009, 10:59 PM
Randy2631's Avatar
Randy2631
Fixed
Thanks to everyone for your help. it turned out to be a combination of things. i had the wires to the solenoid on the wrong post but switching to the right one didnt fix it because the solenoid posts were stripped. i replaced the solenoid and finally switched the wires to the right post and when i turned the key it cranked....and kept cranking when i pulled the key out. turns out the new solenoid i bought was bad. after i got another new solenoid and got the wires on the right post everything worked and the engine ran great.
WootDogg
1997 - 2003 F150
15
09-27-2020 04:54 PM
siuhortguy
05-05-2016 05:35 AM
boaterdude83
1997-2006 Expedition & Navigator
03-12-2014 10:10 PM
PhilcoPGM
12-07-2010 07:44 PM
dvndog
1997 - 2003 F150
06-19-2006 03:09 PM
Quick Reply: No Power
