1972 Ford Explorer
Old May 20, 2009 | 09:25 AM
joedellcarter's Avatar
joedellcarter
1972 Ford Explorer
Hello all...I usually post on the 48-60 board, but I have a line on a 72 Ford F100 Explorer long bed 302 3 speed that's been sitting inside for a number of years. The former owner was a bit of a pack rat so I wasn't able to thoroughly look the truck over with all the junk in the way, but it seems very solid with the exception of some rot above the trim midway up the bed sides. Is this a common place for rot to occur?
How rare is the Explorer option that year?
thanks!
Old May 20, 2009 | 11:31 AM
frankensteined_67's Avatar
frankensteined_67
the rot i a common thing. the bed is split right there and so moisture gets trapped in
that area. you might want to look under the cab at the supports they tend to get rotted
too.
for the Explorer package i don't know how rare that would be.
Old May 20, 2009 | 11:00 PM
SPIDER-1's Avatar
SPIDER-1
Yes, It is a common spot due to the split of the sheet metal I am currently wanting to try out a rust eating chemical(don't know of a brand yet) and then use some seam sealer sold by Eastwood to see if this will stop it from spreading. The cab is also a common area The front supports under the floor board and the back corners as well as the kick panel areas where it meets the floorboard.
Old May 21, 2009 | 08:27 AM
joedellcarter
yeah, I've been brainstorming a few ways as to how I'd fix that. I guess I'd grind the seam out until I hit enough of an area where there was no more rust and see how the factory filled the seam. I'd probably weld in a piece or fill the seam with body caulking. Hard to tell having only looked at it once.
Old May 21, 2009 | 03:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Explorers are a special limited edition trim and option group, so yes they are rarer than the normal production run. They were only made a few months out of the year and had their own seprate brochure.
I have a gallery about each year Explorer you can see here...
https://www.ford-trucks.com/user_gal...&albumid=16651
berlincam86
74
Mar 17, 2019 09:26 AM
coyotedave
May 30, 2017 03:49 PM
berlincam86
'80-'86 FAQs (Frequently Asked Questions)
59
Sep 30, 2016 12:20 PM
Massachusetts Ford
New Member Introductions
Aug 29, 2016 04:05 PM
supercuts
Ford Truck Parts for Sale
Jul 24, 2016 12:52 AM
