Bedsides interchange
Old May 20, 2009 | 07:18 AM
ohiofordnut's Avatar
ohiofordnut
Heres what i want to do i have nos 8ft bedsides for a 78 f150 4x4 and i need a bed with a good floor but everyone wants a arm and a leg for theirs so i was wondering if i could put my 78 bedsides on a newer bed and would the 78 tailgate fit also and if anyone has a 8ft bed that has a good floor let me know then maybe i can finish this truck to give it to my son for a graduation present thanks for your help and time
God Bless
Old May 20, 2009 | 08:38 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Anything is possible with a grinder and a welder!
My memory is fuzzy, but I think somebody else did the same thing not too long ago. Try the search feature.
Josh
Old May 20, 2009 | 01:57 PM
hpheltersnach's Avatar
hpheltersnach
Ya, you can. I have a 79 short bed that was done too. It actually had long box sides cut down to fit and put on a later (like about 90 I think) box. Putting long sides on a long box would be easier. The tail gate hardware on the newer beds is different though. I'm sure someting can be done I just haven't got to that yet. I was thinking I might be able to put an older style skin on the newer tailgate.
Old May 20, 2009 | 02:47 PM
Diesel_Brad's Avatar
Diesel_Brad
The insides of the beds are the same from 73-97. With that being said. I am an 80s man so i know 80's. 80-82 uses one tailgate hardware. 83-86 uses another tailgate hardware. 87-97 uses another. I believe 80-82 is the same as the 70's
Old May 21, 2009 | 11:03 AM
hpheltersnach
Thanks for the info. That should help when I go to address the tailgate issue. The hardware on the box I got is definitly different than 73- 79. I don't know what year the box is cause I bought it on a local truck that I got for parts. But the work was done in a body shop where a buddy of mine works. So I do know that it was done right. He's not a truck guy so he doesn't know the year of the donor box, just that it was a newer one.
Old May 21, 2009 | 03:41 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The 1980-1982 Tailgate hardware is different, than 1973-1979. But they are simular in looks and function.
The taillight/tailgate pillars are also different, but can be modified.
But if you use the taillight/tailgate pillars off the 1973-1979 bed, as well as the outer bedsides, it would be the easiest.
The floor, the front wall and inner bedsides are interchangeable and havent changed much between 1973-1996-select 97 etc.
GM4WALLS
15
May 11, 2016 12:34 PM
fordgo
May 12, 2015 11:33 AM
Buyerz
Apr 16, 2015 10:56 AM
Holiver31
Jan 18, 2011 05:52 PM
jr66coupe
Feb 15, 2010 09:41 PM
