free mods
Old May 19, 2009 | 10:29 PM
benblaque's Avatar
benblaque
free mods
lets test this out....
say you have a stock f150 4.6 or 5.4 mod...
What are the free modifications to increase hp/trq??
Old May 20, 2009 | 07:10 AM
2000Ford2000's Avatar
2000Ford2000
None, nada, N/A
Old May 20, 2009 | 06:40 PM
LxMan1's Avatar
LxMan1
Drive downhill
Old May 20, 2009 | 09:40 PM
LMS Residential's Avatar
LMS Residential
Drive downhill AFTER removing bed and passenger seat, adjust kanootin valves to full open.
Old May 21, 2009 | 01:18 AM
benblaque's Avatar
benblaque
not the answers i was looking for...
i know from owning a half doz fox body mustangs. i could increase hp my removing smog pump.
removing airbox silencer
redirect the water hose on the throttlebody spacer
doesn't cost anything for these... anything similar for our 5.4 trucks?
Old May 21, 2009 | 06:47 AM
LMS Residential
Hey Ben,
Sorry about the sarcasm, think everyone was just reiterating that adding HP = $$$$. Well back in the last century, I had a 76 SD 455 TransAm that had twin smog pumps. After accumulating enuf pulleys and brackets and plugs for the 3 miles or so of useless (I thought) vacuum lines, I removed both, bypassed the cat, rejetted the carb and advanced the timing about 2 degrees if my memory serves me well. My guess was about 75 FREE horsepower or at least it felt like it. That car would smoke thru 1st, patch second and chirp third with the TH400.
Forward to the 21st century. No more crude smog pumps and a very sophisticated pollution control system well integrated into the electronics and mechanicals. The 5.4 is a great motor IMHO but it can seem sluggish particularly in a nearly 4 ton vehicle. If you'll read through these forums, seems like the best gains in hp for that motor come from the addition of custom tunes, regearing and a less restrictive cat back exhaust; none of which are free. Oh, and for about 7 large, theres a couple of Saleen or Roush superchargers that should pin you in your seat. They're made specifically for the F150 but should bolt up to your SD as well although your retune would have to be suited to the SD.
-Ed
Old May 21, 2009 | 11:28 AM
2000Ford2000
Cheapest is probably a chip tuner, at around $550
Crewcab Turbo
May 10, 2011 08:48 PM
gonzo596
Jan 13, 2010 03:44 PM
stockf150stlyeside
Modular V8 (4.6L, 5.4L)
Dec 21, 2004 05:10 PM
FireAm94
1978 - 1996 Big Bronco
Mar 12, 2004 11:59 AM
MGT351
Mar 28, 2002 12:43 PM
