Does anybody have part #'s or know the type of hose that connect the FPR to the lift pump. I need to replace one and figure I will do all of them. Thanks alot
You don't need to go to the dealer, you can get the hose at your favorite parts place. You'll need both 3/8 and 5/16 hose. Just make sure that you get high pressure fuel injection fuel line. It will be marked as "SAE30R9" on the hose, Do not use the cheaper 30R7 hose, it will not take the fuel pressure. I'd just buy a foot of each that way you either have extra or dont have to go back to the store because you cut a piece to short
3/8” hoses: 2 required 2 “ (fuel tank to pump &
low pressure feed from filter to pump)
1 required 2 7/8” (fuel pump outlet to filter)
5/16” hoses: 1 required 1 ¾” (return from regulator to tank)
If you don't have a hose on the fuel bowl drain this would be a good time to put on there. It's 5/16 and just use whatever you don't use on the regulator return
