Help! Dealer woes.
Excellent question.
Frequent oil changes are always a good preventative measure. It helps to limit the oxidizing process that you are describing.
Another path that we recommend is using our Blue Diamond product which is a pure synthetic (not a blend) 5W-40 and the bypass filter system. Our customer who has 500K plus now on his 6.0 using this system goes 50K-60K plus between changes and is still using his original injectors and is not having the other typical issues.
If you add it up, it is a savings in time and effort as well as cost.
Or one could just run a treatment through periodically and use the Rotella or equivalent at greater intervals and do it that way.
Many options are available.
Hope this helps!
Dan
Excellent question.
Hope this helps!
Dan
PROVE IT!!!
I can't find a big enough BS flag emoticon for that one...
Trust me, my post would be quite lengthier then what it actually is going to be because it would be filled with a lot of words that boiled down mean "that is just crap".
I hope that was a typo, because unless you have some damn good proof, I'm really going to have a hard time believing anything that you type from here on out. Which was pretty close to happening already, but it damn sure is going to happen now.
This is just...well....crap(not the 4 letter word I would choose, but I have to be on my best behavior sometimes).
I'm waiting to see objective info to back up these claims....I understand the importance of sponsorship for the site...We have to watch out for ourselves, as members, also..
I really wouldn't count on anything from him, he doesn't reply much after he says what he has to say to hock the product and then he moves on. Really frustrating to be honest, I'm trying to keep an open mind, but this last post definately takes the cake and that proof really better be damn good and I would want more then just my money back from the cost of the product, I'm wanting them to back up my warranty as well.
I have to plug our product.
You can help avoid the dealership with future repairs of injectors or related engine breakdown by running Hot Shot's Secret. It was tested and proven to be safe and effective for the 6.0...it helps avoid stiction, the cause of injector failure.
If it saves one of these future trips to the dealership it has paid for itself many times over.
You can find us online at Lubrication Specialties | Diesel Motor Oil | Primrose Engine Oil | Fuel Additives | Oil Additives | Engine Restore| or
Good Luck!
Dan
He has HARD facts that his bypass system is a nice option, but completely unecessary....IF you change your oil @ 5k or less intervals. The injectors on the 6.0L shred the oil viscosity regardless of how clean the bypass system makes it.
This stuff sounds like snake oil to me.
RIDICULOUS CLAIMS FROM A TRAVELING SALESMAN
I dred injector or just general oil threads in here lately because of it.
And to tracyclifton:
I picked up my truck after having the turbo replaced. When I got home and popped the hood, the technician had left one of those black bungee cords with the metal hooks just lying across the top of my engine. If it had fallen down into the serpentine belt it could've been a mess. Sorry you had trouble and hopefully it'll get fixed.
Mark
