turn signal question
Old May 18, 2009 | 11:39 PM
fisheasy's Avatar
fisheasy
Question turn signal question
Hello guys!
I have a 1990 F-350 7.3 IDI and I was noticing my turn signals were not working! I was wondering if someone could help me diagnose my problem as I am not sure what to check. Thanks and let me know if a little more info is needed
Old May 19, 2009 | 12:22 AM
farmert's Avatar
farmert
What does it do? Any blink or sound? Have you checked the fuse and bulbs?
Old May 19, 2009 | 12:50 AM
rupejosh's Avatar
rupejosh
flasher is a good idea to check.if when you hit the turn signals and you dont hear clicking and your fuses are good thats what i would guess.
Old May 19, 2009 | 09:30 AM
redbug's Avatar
redbug
I've had two turn signal issues with two old trucks. One a 62 GMC and the other my 85 F250. It was only one side though... Checked the usual, fuses, bulbs, blinker. Then I started tracing the voltage and I ended up in the column on the turn switch. Both times It ended up being the little rivet that attached the wire to the switch. Squeezed the rivit a little bit and all was well...
Old May 19, 2009 | 10:12 AM
fisheasy's Avatar
fisheasy
yeah i dont get any noise when i turn them on. Where is the flasher located?
Old May 19, 2009 | 01:40 PM
rupejosh's Avatar
rupejosh
its the circle shaped thing in the fuse box.i believe bottom right hand corner.they are only like $5 too.it pulls out just like a fuse
Old May 19, 2009 | 04:09 PM
fisheasy's Avatar
fisheasy
thank you guys for your help!
rupejosh i found the flasher and put a new one in. That was my problem. Everything is cool now. thanks again for your help
Old May 19, 2009 | 04:11 PM
Brojon2002's Avatar
Brojon2002
I just replaced mine with the electronic one. I pull a 31ft toy hauler and it has a ton of lights on it.
Old May 19, 2009 | 07:36 PM
rupejosh's Avatar
rupejosh
no problem bud thats what were here for.
