Need advice !!!
Old May 18, 2009 | 06:28 PM
doc582000's Avatar
doc582000
Need advice !!!
NEED ADVICE !! My trcuk is a 2004 5.4 screw
Lariat all good but i noticed that it seem kind slOW coming from stop it take lot time to get power it dont seems to have 300 hp like they said, some topic mentioned reflashing PCM but since my is a 2004 i do not know what to do i took it the dealer and all they say its working fine a friend of mine has a truck like mine and it is a lot of difference on how it feels i dont want to have to buy any aftermarket chip, all i want is to have the power it should. my milage is 60 000
all ways use mobil 1 synthetic.
hope some one knows better!!
Old May 19, 2009 | 05:12 AM
James_24_85's Avatar
James_24_85
All you have to do to reflash the pcm is unhook the negative side of your battery for 30 minutes.
Old May 19, 2009 | 07:14 AM
shorebird's Avatar
shorebird
This simply resets the PCM to baseline settings. A reflash is the changing of settings by reprogramming the PCM. Have the PCM read and the flash version # noted. Find out what is the latest version issued Ford. The PCM will have to relearn YOUR driving habits after a battery disconect. The use of a programmer is a way of reflashing the PCM. The programmer stores the factory settings and flashes a new set of PCM instructions to it. Always keep track of your programmer in order to be able to "return to stock".
Old May 19, 2009 | 11:21 AM
Oldguy4's Avatar
Oldguy4
Have you had this truck for a long time, so you can really tell a difference from what it used to be? If not, than maybe your friends truck has lower gears in back then yours. That would make a difference.
Old May 19, 2009 | 12:17 PM
doc582000's Avatar
doc582000
I had it since day one, and i know had more response, my friend and i have same gear ratios, and same tire size, if i take to dealer what should i let them know or i do i know latest version for my pcm, my truck is 2004 SCREW 2WD Lariat. Thanks if some one knows where to get it or has a flash number PLEASE let me know and olso how do i get mine from OCM...
Thks
Old May 19, 2009 | 04:02 PM
melek4me's Avatar
melek4me
hi,i have also 04 fx4 with 53k on it and with same problem.truck feel like very slow and havy.dealer refresh the PCM they charge me $100.00 dollars for it.today i will fillup my second tank. truck has to learn my driving habits. still feels very slow.
Old May 19, 2009 | 04:44 PM
doc582000's Avatar
doc582000
100 for a pcm flash and how does it feel ? is that a standar price for pcm flash? did it fix it?
Old May 19, 2009 | 10:04 PM
melek4me's Avatar
melek4me
YES,100 for a pcm flush.looks like standart price just to hookup the computer to see the truck has older or newer version program and they said i had a old program.anyway truck feel same as before pcm flush but like i stated pcm has to learn my driving habits.did you change your fuel filter?air filter and if you unhook the negative side of your battery for 30 minutes.same time clean your MASS sensor with contact cleaner to see gonna help or not.
declinetostate
Nov 29, 2012 07:57 PM
btred1466
Sep 26, 2012 04:01 PM
bebeard
Oct 6, 2011 09:41 PM
big78f150
35
Feb 17, 2011 10:21 PM
Tungsten
Oct 18, 2007 04:22 AM
