Rough Idle Problem.....
Old May 17, 2009 | 09:41 PM
John Luther's Avatar
John Luther
Tricky... Here goes...
94 F150 4x4 302 with dual tanks.
Intermittenly, the truck idles really rough. I can tell when this is going to happen before I start it up as the fuel pump will run continuously. Usually, it runs for about 1.5 seconds before I start the truck. 50% of the time I will turn the key to the on position, prior to a full start, and the fuel pump will start to run, but it will run contiueously. Then I will start the truck, and it will idle really rough. The other 50% of the time, the pump will run for about a second, shut off, I will start the truck and it will idle just fine. It doesnt matter which tank I start from. Anyone have any ideas of where to start chasing my problem down?
Old May 18, 2009 | 09:00 AM
Amos Moses's Avatar
Amos Moses
Anyone ever had this problem?
Old May 18, 2009 | 03:56 PM
John Luther
Any takers?
Old May 19, 2009 | 12:49 PM
John Luther
Can anyone point me in the direction as to where the fuel tank selector valve is located? Thinking this may be the problem.
Old May 20, 2009 | 07:09 AM
fmr9's Avatar
fmr9
The time the fuel pump runs, and the idle are both controled by the ECU. I'm thinking you probably have a bad ground that is ok sometimes, and sometimes not. Before I did anything else, I would clean and retighten all the grounds I could get to, and check the plug on the computer for signs of corrosion.
Good Luck Frank
Old May 25, 2009 | 05:58 PM
John Luther
Turns out, it was the computer!
