Sponsored by: Real Truck
locking the hubs
Old May 17, 2009 | 08:04 PM
VTX1800rider's Avatar
VTX1800rider
locking the hubs
It might sound like newbie questions and they are. I have a 2006 350. When putting it 4x4, you just switch to 4 high, right? There is no getting out to turn the hubs? Today I got stuck pulling a horse trailer thru a wet, muddy field to get to the show's parking area. The back end sunk. Having a Expy for years it was turn the **** and go. I got out and went to turn the hubs and couldn't. I thought I was screwed. My old '88 250 and Jeep, you would get out and turn. Just for hell of it, I turn the **** to 4 high and heard a slight clunk. Next thing I knew I was out and moving. I just got the truck and don't have the manual yet.
Is this the way the hubs work now? I don't need to turn the hubs at all?
Thanks
Old May 17, 2009 | 08:46 PM
FI460's Avatar
FI460
I don't actually have any experience with SD hubs, but on my dakota and all of the other vehicles i have seen with an automatic 4wd system the hubs engage themselves. No getting out and turning.
Old May 17, 2009 | 08:57 PM
Lou Braun's Avatar
Lou Braun
The hubs on your '06 have an "auto" position and a "locked" position. When in auto you engage and disengage the hubs by using the 4WD selector switch in the truck's dashboard.
The locked position is used as a manual over-ride to lock the hubs if the automatic feature does not work. It is a good idea to periodically turn the hub lock **** to locked and auto so that you know the manual over-ridt will work if you ever need to use it.
Lou Braun
Old May 18, 2009 | 03:46 AM
VTX1800rider
Thank you...
Old Jul 31, 2009 | 11:25 AM
stutterstan's Avatar
stutterstan
Lou Braun
Is it best to keep the hubs in the "auto" or "locked" position? I just bought my first auto hub truck and I am really not sure? I have a 2000 F250.
Les
Old Jul 31, 2009 | 11:43 AM
12ozd's Avatar
12ozd
Les
Best to run in "auto"
Old Jul 31, 2009 | 12:20 PM
silly34's Avatar
silly34
Several people run them locked year round with no ill effects. I'm not one of them..yet.. I have a vacuum leak so no auto locking for me..
Old Jul 31, 2009 | 12:41 PM
cole60's Avatar
cole60
They are junk as far as I am concerned. They cost round $300 to replace on of them and they set up and you need to force them to the lock position to have four wheel again. After they went bad on me I found out that it is recommended to rotate them from auto to lock to help keep them from freeing up. O and after market hubs like warn or super-winch are half the cost of oems
Old Jul 31, 2009 | 08:09 PM
450wannabe's Avatar
450wannabe
In our '08 450 we were hearing "scratching" noises and at one point, was told it was the drive shaft that was bad. About 3 months later, the same thing this time dealer found the hubs were locked (didn't even know there was auto/lock) and hubs were now spinning. Hubs replaced. Dealer said to turn from auto/lock monthly and to put vasoline around it.
Old Jul 31, 2009 | 08:52 PM
kelly67's Avatar
kelly67
my best friend got tired of lubing his up every fall he got a set of warn hubs with no regrets. He talked me into manual transfer case, with no regrets either
rossgn
Dec 9, 2013 09:18 AM
GobblinTom
Oct 31, 2012 03:18 AM
1976HighBoy
Sep 5, 2012 04:31 PM
sotwclarinetguy
May 20, 2012 05:54 PM
swillett
Jul 12, 2011 03:30 AM
