Sponsored by: Auxito
2003 Rear Rotor Question
Old May 17, 2009 | 03:06 PM
1954blueoval's Avatar
1954blueoval
Does anyone have any advice on getting the rear rotors off of my 2003 F-150? They have never been taken off before and I can not get them to break free. I read elsewhere on here to back off the emergency brake, which I did, and I still can't get them off.
Old May 17, 2009 | 03:42 PM
chaser1602's Avatar
chaser1602
BFH around the flange if you want to use them again.Dont be scared to hit them.Hit anywere if they are being replaced
Old May 17, 2009 | 03:59 PM
paredneck33's Avatar
paredneck33
here's what I do spray alot of PB BLASTER at the hub where the axle pokes through leave it sit for about an hour and then go back and pull them off. You might still have to use a hammer, but you won't fight as much . And do use wd40. It's good stuff just not strong enough to penetrate that much rust. Then before installing the rotors new or old apply a thin coat of anti seize around the flange of the axle, then install the rotor. That way next time they will just pull right off the next time. Works great for me.
Old May 18, 2009 | 04:31 PM
LxMan1's Avatar
LxMan1
That's what I did. PB Blaster and BFH. Let it soak into the hub area for a few minutes than start wailing away. I used the silver anti-sieze on all 4 of my rotors when I did the brakes on my 01.
Old Jun 18, 2009 | 10:28 PM
1954blueoval
I sprayed (and sprayed) penetrant over a weekend and it didn't seem to help. I finally got one off by hitting it with an air hammer, but the left side is stubborn and still won't come off. I hate to admit defeat, but I am almost there. Any other ideas?
Old Jun 18, 2009 | 10:41 PM
2002 F350V10's Avatar
2002 F350V10
heat from a cutting torch around the center hub area of the rotor followed with a big hammer to knock the rotor loose. the 2 rear disc rotors were stuck on my 02 f150 and that was the way I removed them and it took about 1 1/2 hours for both.
