Looking at replacing M5OD and before I buy the ZF I was wanting to get the gear ratio's for all the gears or at least OD. Also regearing rearend and need to make sure it will work.
After about 3hrs on the web I found these 3 ratios used in the ZF on Ford Trucks.
5.72, 2.94, 1.61, 1.00, .76 used on diesel
4.65, 2.60, 1.53, 1.00, .77
4.14, 2.37, 1.42, 1.00, .77
How do you tell the ratio on the tranny. Is it on the identification tag. And just to see what ratio in what truck. If you know the ratio can you post the engine behind and tranny code. Thanks to those who have helped.:-)
