Power steering
Old May 17, 2009 | 10:12 AM
redtruck99's Avatar
redtruck99
Power steering
I replaced a leaking pressure hose on the top of my power steering pump but now I get noise as I turn and my brake pedal talks to me. Do I need to bite the bullet and replace the PS pump?
Old May 17, 2009 | 10:17 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
What did you put in the pump for fluid? I hope you know that the pump takes ATF, not powersteering fluid.
Old May 17, 2009 | 10:20 AM
redtruck99's Avatar
redtruck99
DOH. I'm thinking I need to flush and use ATF
Old May 17, 2009 | 10:23 AM
mueckster's Avatar
mueckster
How low did the pump get on fluid? Air in the fluid (foaming) will cause that noise, too. It has to work its way out. Did the noise decrease after sitting for awhile?
miller_feed
I think that is a good idea.
Old May 17, 2009 | 10:27 AM
redtruck99's Avatar
redtruck99
Thanks for the welcome Jim . Is macron ok for a 99 F250?
Old May 17, 2009 | 10:31 AM
mueckster's Avatar
mueckster
If you mean Mercon, "yes''.
Old May 17, 2009 | 10:36 AM
miller_feed
Yes, Mercon-V is good to use. Some use synthetic ATF.
Old May 17, 2009 | 10:43 AM
PaysonPSD's Avatar
PaysonPSD
If you buy Mercon V you will be getting synthetic.
Old May 17, 2009 | 10:53 AM
miller_feed
I must have missed this. Thanks Robin.
EDIT: I think CRS has a play in this.
Old May 17, 2009 | 11:04 AM
PaysonPSD's Avatar
PaysonPSD
Sometimes I forget I have CRS.
Old May 17, 2009 | 11:13 AM
redtruck99's Avatar
redtruck99
Mercon in ..and still noisy. Pump?
Old May 17, 2009 | 12:01 PM
12ozd's Avatar
12ozd
You can try to bleed some air;
Jack up the front wheels,turn lock to lock a few times.(engine running at idle).
Old May 17, 2009 | 01:19 PM
RussB's Avatar
RussB
Also check the hose between the PS pump and the brake master cylinder.. Mine had a slight hole in it once and the brakes and the steering didn't work all that well and I have noise coming from everywhere !
