need help againe
Old May 16, 2009 | 07:44 PM
Bustaduck's Avatar
Bustaduck
need help againe
went to pass a slow car on the way to work was running about 65 mph I floored it to get on around well don't know how to exsplane but the truck started bucking,skipping, are somthing to that nature. but as soon as I let off truck run fine.I'm thinking transmission don't think it's motor related because it does the samethig when I pull my trailer any IDS
Old May 16, 2009 | 08:22 PM
bismic's Avatar
bismic
With what you have described, the only thing I can come up with is a couple of Broadcast Messages that say an updated "calibration" (software flash) will correct it. Have you kept up with your transmission fluid changes?
Old May 17, 2009 | 06:42 AM
Bustaduck's Avatar
Bustaduck
well the best that I could money is a little tight around here the stangest thang happend the other day. it was sitting in park running I rev up the motor a couple of times then it wouldn't go in gear fw or rev so that leads me to thank it's tranny. do you know what they call the new flash? I've had few reflashes thanks
