how to remove frame rivets??
Old May 16, 2009 | 04:44 PM
DJdemon6696's Avatar
DJdemon6696
we tried grinding it but it just wont come out.. any ideas?
Old May 16, 2009 | 05:15 PM
Conanski's Avatar
Conanski
How much did you grind off? If you grind the rivet down flush with he metal you should be able to press it out with a BFH and an appropriately sized punch.
Old May 16, 2009 | 07:02 PM
1966Tbird's Avatar
1966Tbird
or you can drill them out
Old May 16, 2009 | 08:07 PM
blakem_85's Avatar
blakem_85
I usually cut them off flush with a torch instead of grinding, but that takes a bit of finesse. In some cases you can heat up the frame around the rivet depending on its location. Drilling a 1/4" or so hole in the center of the rivet can help loosen them sometimes too. Drilling them completely out is also an option, just more time consuming. Also, when driving them out make sure that if there is something riveted on the opposite side of the rivet you're driving out that it is loose from the rivet, easy way to bend up cross-members and brackets.
Old May 17, 2009 | 01:05 AM
snipAR-15's Avatar
snipAR-15
air hammer maybe?
Old May 17, 2009 | 04:14 AM
Lazy K's Avatar
Lazy K
As blakem says the best way is to drill a hole into the rivet to "relieve" it. Just to the depth of the metal, not right through.
Old May 17, 2009 | 04:44 AM
Towmanjbo's Avatar
Towmanjbo
I use a cut off wheel to slice an "X" pattern in the head and then use my air hammer to chisel the head off. Then swap the chisel to a punch on the hammer and knock it out.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
