Keypad Question
Old May 15, 2009 | 11:37 PM
bynan2007's Avatar
bynan2007
Keypad Question
I just bought a 2007 F150 4x4. I have the original code for the keypad. I had to call the original owner to get it cause the dealership I bought it from didn't have it. Is there a way to change or reset the code?
Old May 16, 2009 | 04:15 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the factory keycode is hardwired. You would have to change out the little module on the back wall to get a new keycode...or maybe the dealer could reprogram it for you.
The only thing you can change are the 2 personnel pin codes...but the original will always work as well
Old May 16, 2009 | 08:00 AM
shorebird's Avatar
shorebird
And that's all there is.
Old May 16, 2009 | 09:31 AM
bynan2007's Avatar
bynan2007
Thanks. My next project is to install remote start. Can I get a remote start from Ford that will still allow me to use the keypad?
Old May 16, 2009 | 10:36 AM
bridge's Avatar
bridge
Sick 'n Tired
Use the keypad to what, start the truck? Your keypad will always work to lock/unlock your doors regardless of what system you install over it. It won't, however, disable an aftermarket remote-start/alarm system. I've got a Clarion (Ungo) remote-start/alarm on my truck; if I use the keypad w/o disabling the alarm the doors unlock and the siren sounds.
Old May 16, 2009 | 03:02 PM
FTE Trigger's Avatar
FTE Trigger
Here's your original post for reference...
https://www.ford-trucks.com/forums/8...-question.html
Old May 17, 2009 | 01:00 PM
Ryan50hrl's Avatar
Ryan50hrl
It will however deactivate the ford code alarm remote start/alarm....i use mine all the time when the alarm is on
