It begins...
Old May 22, 2009 | 07:57 AM
bashby's Avatar
bashby
I had someone (local kids I assume) break the drivers side window out of my truck when it was parked on the street in front of the house. They didnt take anything, the door wasnt even locked! Luckily I found a free window but it was a PITA to clean up and replace. Every time I slam the door and hear the broken glass in the bottom I get a reminder
Old May 22, 2009 | 08:34 AM
LARIAT 85's Avatar
LARIAT 85
Connect the vent line to a vacuum source on the carb and let the vapors burn in the combustion chamber. It will not hurt anything and helps the environment.
I'm not a tree hugger but it's just a vent and you won't smell gas vapors around your truck when it gets hot and your fuel expands.
That must be why my truck smells of gasoline when I park it under my carport. Do you use ported vacuum for this? Do you use some sort of check valve? And did you have to adjust your mixture screws when this line is hooked up?
Old May 25, 2009 | 03:53 PM
Sycostang67's Avatar
Sycostang67
Got the motor dropped in last night, should have it running on thursday. I still have to get oil, coolant, hoses, etc.
Old May 26, 2009 | 12:47 AM
Jmeyer1990's Avatar
Jmeyer1990
Are you planning on getting some new manifolds?
the ones in the picture kinda ruin the beauty of the engine :/
Old May 26, 2009 | 07:47 PM
Sycostang67
Headers are planned in the future, after paint. I was at least able to switch to non-smog manifolds for now that didn't require modifying my pipes.
Old May 26, 2009 | 07:53 PM
Jmeyer1990's Avatar
Jmeyer1990
Ah, cool, I have a set of non smog manifolds too very happy I am with them
Old May 26, 2009 | 07:58 PM
Sycostang67
I figured it was easier than trying to plug all 8 holes in the old smog manifolds. I did retain the injection tube that goes to the back of the heads in case I have to pass a smog test some day. At lest I will only have to add 1 smog pump instead of 2.
Old May 26, 2009 | 08:16 PM
Jmeyer1990's Avatar
Jmeyer1990
Yeah, it sounds easier haha.
What states have the smog test?
I know Nebraska doesnt, neither does Iowa, otherwise I wouldn't have had the Topaz or my current F250 haha
Old May 27, 2009 | 01:13 AM
Sycostang67
The smog testing in Idaho varies by county. I dont have to test, but my parents who live 7 miles away do.
Old May 27, 2009 | 01:24 AM
hittman1422's Avatar
hittman1422
you really ought to post up some pics of that 67 stang with the 351W up... i know its not a truck but its a ford and i wanna see it, so show me!
Jmeyer1990's Avatar
Jmeyer1990
oh, so it really just depends on the local government?
Old May 27, 2009 | 03:02 AM
Sycostang67
Here you go.
As far as I know. I have heard on the news that the state is pushing for my county to initiate smog testing, even threatening to withhold certain funding if we dont.
Old May 27, 2009 | 03:12 AM
  #28
hittman1422
thanks now my keyboard is ruined due to drool damage....
sweet car man!
Old May 27, 2009 | 03:47 AM
  #29
Jmeyer1990's Avatar
Jmeyer1990
ah, well im glad that I live in a part of Nebraska where everyone could care less.
The rules of, the one with the biggest truck at a 4 way intersection goes first, followed by the loudest, followed by the ugliest, followed by ricers really does apply here
Old May 27, 2009 | 10:38 AM
  #30
Diesel_Brad's Avatar
Diesel_Brad
you need a bigger air cleaner. that is just going to choke the engine, not enough surface area
