need help with trailer plug wiring
Old May 15, 2009 | 12:57 PM
largefries's Avatar
largefries
I just bought a trailer a few months ago. I towed it home and all the lights worked. I wired a brake controller in, and now the running lights on hte trailer are not working. The brake lights are working. I checked the fuse (#4 in the engine compartment) and its good. I check the voltage at the pins on the truck and I have no voltage from + to -, no voltage aux to -, no voltage on running lights pin, but do have 12 volts on the brake pin. What else can i check?
I also diconnected the brake controller and it did not change
Old May 15, 2009 | 01:08 PM
just another truck's Avatar
just another truck
Can you post the schematic you wired to??
Old May 15, 2009 | 01:22 PM
largefries's Avatar
largefries
Scanning it would be difficult, I don't have have one available. But there were only 4 wires. One directly to pos (through a breaker), another to neg, one to a wire from the brake pedal(under dash), and another to the trailer plug (blue wire, trailer plug).
Old May 15, 2009 | 01:38 PM
just another truck
I would check fuses right now, Fuse 4 is a 20 amp, I believe it will be under the hood...
Old May 15, 2009 | 02:12 PM
largefries's Avatar
largefries
yeah # 4 is good. this is frustrating, I wanted to leave to go camping with the family tonight. its a no go if i can't figure this out. If I'm getting 12v on the brake wire, the ground should be fine. the signals work too. what is the pos terminal for? it doesn't have voltage nor backup lights, nor running lights. thats the top 2 pins and center, on the plug.
Old May 15, 2009 | 04:05 PM
fifthwheel01's Avatar
fifthwheel01
Don't know if this will help you but, I went to uhaul, bought a "plug in splice" 7 wire combo w 4 wire plug took 5 minutes to install no mistakes possible. It just plugs in directly to your existing ford wiring harness in between the tail lights. Think it was like $29. Quik ezy -go CAMPING!!!!!
Fifthwheel01
Old May 15, 2009 | 04:13 PM
fifthwheel01
Forgot to ask- what kind of controller did you get and did you get the direct plug in adapter for your truck that plugs in right under the dash.
Fifthwheel01
Old May 15, 2009 | 04:21 PM
fifthwheel01
Also you can go to e-trailer.com and get lots of info and wiring diagrams/schematics and more if your have a camper you'll bookmark this one.
Old May 15, 2009 | 05:04 PM
largefries's Avatar
largefries
I'll check those sites, thanks. I've checked every fuse related to towing and/or lights. they are all good. I've found a diagram with a "trailer running lights" relay. I think it is in the relay block behind the stereo. I don't know which of the four it is, and ford wants the part # to order it. jeeesssshhhhh! I just want to get going!
the controller is older drawtite. no adapter, i wired it straight in.
Old May 15, 2009 | 05:39 PM
just another truck
trailer relays are are under the hood, normally, they are to the left of the fuse block, looking at it from the front of th etruck.l
Old May 16, 2009 | 07:58 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Bumping as I went through something similar to this last week. Hoping that he gets it fixed!
Old May 19, 2009 | 11:08 AM
largefries's Avatar
largefries
Did it happen after you installed a brake controller? I'm trying to narrow down the variables. I have no idea if its something I did or and exisitng problem with the truck because this is the first thing I've towed.
BTW, went camping with the trailer anyway Just drove during the day. I was awsome! family loved it! truck towed well. Just wondering how a stock truck should pull up a 7% grade. I have a 24ft trailer and I could only go 70 to 80 kmh (45 to 50 mph, eh!). Rpm about 2600, i didn't want to push 3000 up a long hill. I was passed by a toyota towing the same size rig! I was shocked.
Old May 19, 2009 | 11:53 AM
fifthwheel01
Good thing that toyota passed you up!!!
You dont want to be in front of them going downhill.
Always keep them where you can see them!
Take it your trailer brakes are working proper?
Old May 19, 2009 | 12:39 PM
largefries's Avatar
largefries
the brakes work, but the running lights still don't. I'll keep you posted how it goes, figuring this out. It may be the relay, I just have to find it.
Old May 19, 2009 | 01:38 PM
just another truck
Pop your hood, on the right there is your fuse box, it has relays in there as well, to the left,mounted on the outside of the fuse block is you trailer relays..
