General Diesel Discussion
1992 Ford B700?
Old May 17, 2009 | 02:21 PM
nevrenufhp's Avatar
nevrenufhp
See the link in my signature for the fuel screw(listed with the 84-92 DT466). It takes about 10-15 min. to do, and gives around 20-30hp(depending on how much you back out the screw). The bus is geared to hit the engine's gov as a speed limiter. You can tighten the gov springs to get more rpm, but that lowers fuel economy....but sure wakes em up. You can easily hit 3200 rpm without it grenading, just dont hold it there very long.
Old May 17, 2009 | 02:45 PM
Orpackrat's Avatar
Orpackrat
I just want the bus to have a little more power for them hills after I load it up with the motor home internals and passengers. I have several long trips planned this summer and the bigger one from the Oregon Coast to Ontario Oregon over several mountain passes. Sure it will burn a little more fuel but I would be nice to actually get up the mountain.
Normal operating RPM on our buses is about 2200 and that gets you rolling at a decent speed but it would be nice for some extra RPM for the hills.
Old May 17, 2009 | 03:00 PM
nevrenufhp's Avatar
nevrenufhp
The 89 F700(7.8) we have at work shifts at 2900. It's had the fuel screw adjusted, gov springs tightened 3 clicks, and timing advanced a smidge. They will usually go up in mpg, mostly because it doesnt need to be wound out all the time to get going. Even if you just hit the fuel screw only, you will like it! If it's still under a mechanic's care, see if they'll advance the timing 3-4 degrees from stock. Or, set it to at least 16*.
Dave R.
Electrical Systems/Wiring
13
Aug 22, 2021 08:39 AM
lioneyes
May 17, 2020 08:42 AM
CHUCK48-50
42
Dec 26, 2016 08:05 PM
RandomElement
Large Truck
Jan 21, 2013 02:17 PM
motocrossdude666
Feb 25, 2008 11:43 PM
