Trailer Hitch Question
Old May 14, 2009 | 09:28 AM
pmhvps's Avatar
pmhvps
I have a 1969 F-100. It has a bumper with a 2" ball for a trailer. I would like to put on a real trailer hitch bolted to the frame. Did the frame have any changes over the next several years? I was looking at a hitch that would fit a 1973 and up to 1979 F-150. I asked if it would work on a 1969 F-100 and the guy said, maybe........good answer.
Mike.
Old May 14, 2009 | 10:55 AM
Ford_Six's Avatar
Ford_Six
The 73-79 frame is about an inch wider, so it may or may not work depending on how it mounts.
On my F250, I took an old 2" receiver center frame, cut it down to fit between the frame rails, and welded on 3.5"x9" plates that slid into the frame. I put these in place with eight grade 8 1/2" bolts, and cut a hole in the plate area of the bumper to pass the hitch through. When not towing, I just pull the hitch out, put the plate back there, and it looks all stock.
Old May 14, 2009 | 11:34 AM
jowilker's Avatar
jowilker
hoss, I believe if you go back and remeasure you will find the 73-79 chassis rails to be more than an inch wider that 57-72.
Mike grab one for a 72 down for fit.
John
Old May 14, 2009 | 12:37 PM
pmhvps's Avatar
pmhvps
Thanks guys.
Mike.
Old May 15, 2009 | 11:23 AM
BradyCouchman's Avatar
BradyCouchman
while we are on the subject does anyone know of a company that sells recivers for 72 and older trucks?
Old May 15, 2009 | 12:37 PM
jowilker's Avatar
jowilker
I just Googled Reese, and they do. I suspect all of the manufacturers have them.
Did you check it out??
John
Old May 15, 2009 | 01:05 PM
BradyCouchman
no not really, just didnt know if anyone knew off hand
Old May 15, 2009 | 03:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thru 1972, and on 1973/77 F250 4WD's (High Boys), the rear frame rails are 33 1/2" apart.
On everything else after 1972: 37 1/2" apart.
Old May 15, 2009 | 06:48 PM
jowilker's Avatar
jowilker
Well, that's about an inch isn't it?????
John
