headlights
Old May 13, 2009 | 08:52 PM
poppajoeblow's Avatar
poppajoeblow
headlights
need help with headlights cannot get them to work i have power at switch and power under the hood at firewall then nothing at dimmer switch or headlights. i hooked a wire from switch to headlights and they work but when parking lights are so are headlights. i see no broken wires can any help please.thanks
Old May 13, 2009 | 10:17 PM
Julies Cool F1's Avatar
Julies Cool F1
HI PJB,
Well, this sounds fairly simple. Lets review - you know you have power to the switch, and you know the headlight bulbs are good because you got them to light during trouble shooting.
So you have one of three problems: Your headlight switch is bad, your dimmer switch is bad or your wiring is wrong or disconnected.
You are talking about a 51 F1 as your data page tells us. So, first, check your headlight switch. I'm going to plant a drawing of the correct headlight switch wiring for your 51. In the two spots where it shows power coming in from the "hot bus" that means from your circuit breakers. Here is the power in flow to the headlight switch:
Name:  S 1951 and 52 Circuit Breaker Configuration and Wiring.jpg
Here is the picture of the headlight switch:
Name:  H F1 Headlight Switch Wiring.jpg
Check to make sure you have power not only going in, but coming out at the right places. If not, the switch is bad. Which in this case sounds like the case - it might be bad but it sounds more like it's mis wired(and thus the parking light thing).
Next is the path to the dimmer switch. Take your meter and check for power in and out.
Name:  U F1 Traditional High Beam Switch.jpg
Lastly is proper wiring. The headlights should flow the same as they do in this diagram.
Be sure to ensure that all your bullet connectors along the lines are connected and tight - you might just have one that has come apart.
Good luck!
05 f250 6 inch lift
Jun 29, 2016 07:40 PM
mustangpt
Apr 22, 2015 09:59 PM
RangerDude17
Jan 26, 2014 03:30 PM
jaymorris
Mar 3, 2007 03:31 AM
