I have an oil leak on the front drivers side of the motor that seems to be getting worse. Just wondering if there is a known weakness area there for me to look for before starting the hunt?
There are plugs on each end of the HPO oil rails on the head. The plugs have an O-ring in there which over time can weaken and leak. You might also check around the valve covers.
Thanks for the info. How hard is it to get to? I think there is a link to the repair manual so I can get a look at it, but I have lost the link. Anyone else have it?
Well it's not the HPOP, all dry and no oil in the valley. Valve covers and head plugs dry. The leak is lower on the front drivers side, I just can not see were it may be from. Front main seal????
edit: I see the leak. It is from a line going into the block just above the oil pan on the driver side. Anyone know what this line is and would it be just an "O" ring?
