Carb vs. EFI Head Difference
Old May 13, 2009 | 12:58 PM
jbrown9709's Avatar
jbrown9709
I'm considering converting my 79 F250 w/ 460 to EFI using late 80s EFI components (intake, injectors, fuel rails, etc) and likely Megasquirt for control. I'm aware that there is a significant difference between carb heads and EFI heads regarding lineup of intake passages. Thus, I know I'll need to use EFI heads in order to use the EFI intake. My question regards the exhaust side. I have some high $$ L&L fenderwell headers that I don't want to give up. Does anyone know how the EFI heads match up to the Carb heads on the exhaust side?
Thanks,
Jeff
Old May 14, 2009 | 01:57 PM
The "Mad Porter"'s Avatar
The "Mad Porter"
Thanks,
Jeff
The EFI cylinder head exhaust bolt centers are raised .560" of an inch vs all early castings. In addition the headers for the early castings will not seal at the top of the fuelie castings exhaust ports unless you drop the header flange by redrilling the holes.
The later F3TE heads have a larger itake valve than the E7TE castings and flow better on the intake side. If you upgrade the intake valve on the E7's to the 2.08" size valve with a 1.89" vertical bowl hog they will flow to with in a few cfm of the F3's.
Old May 14, 2009 | 02:45 PM
Bear 45/70's Avatar
Bear 45/70
The intake ports are different and that's why the carb manifold will not work with the EFI heads and vise-a-versa.
BaronVonAutomatc
Apr 25, 2016 04:22 PM
DrZoom
Ford Truck Parts for Sale
Dec 23, 2015 05:12 PM
gman21583
Sep 17, 2015 01:51 PM
nlareau
Sep 6, 2014 02:45 PM
rustywheel68
May 15, 2011 09:25 PM
