Need door adjusting wrench
Old May 13, 2009 | 11:52 AM
killforfood's Avatar
killforfood
Who makes a good wrench for adjusting doors on the OBS.
I have a 1997 f350 crew cab with a saggy drivers side door. It was fine till a wind storm ripped the door out of my hand and sprung the hinges a bit.
Old May 13, 2009 | 01:07 PM
Action4478's Avatar
Action4478
The best way to fix it is to decide upper or lower , ,or both (look for a gap at the pillar). With the door open , find a piece of steel ,a socket or other ,that will fit in the hinge(keep it on the hinge surfaces only) & keep the door from closing . With the hinge blocked open , try closing the door a little at a time ,while watching the gap at the pillar ..A few tries may be necessary, using the door for leverage .Don't over do it ...
The hinges are most likely fine ,its the surface of the A pillar that's bent
Old May 13, 2009 | 02:07 PM
killforfood
Rick,
Thanks for the tip. It's little tricks like this that help the pros beat book rates.
Old May 13, 2009 | 04:34 PM
Action4478's Avatar
Action4478
There aren't many other ways to do it ,other than door off & a BFH....
Very time consuming ...
Hopefully ,the paint did'nt get damaged on the edge of the door...
Old May 13, 2009 | 05:26 PM
killforfood
Nope, Got lucky there.
Anybody know what crazy shaped box end wrench will best reach the hinge bolts. I'm sure to need some fine adjustments for proper latching.
Old May 13, 2009 | 06:37 PM
Action4478's Avatar
Action4478
Its a 13mm ..if you do as I said ,nothing more will be needed ...
99StrokeXLT
22
Oct 21, 2013 11:28 AM
yellow78ford
Sep 27, 2006 06:30 PM
fatdaddy
Paint & Bodywork
Oct 30, 2002 03:08 PM
Jan 16, 2002 08:22 PM
davie
Jul 31, 2001 09:41 AM
