Volt gauge
Old May 13, 2009 | 10:01 AM
MINER DOUG's Avatar
MINER DOUG
Volt gauge
What is the proper way to wire a volt gauge in a 2002 powerstroke?
Old May 13, 2009 | 10:13 AM
megawatt00's Avatar
megawatt00
I get the feed from the batteries.
Old May 13, 2009 | 10:23 AM
12ozd's Avatar
12ozd
Don't know if this was part of your question or not...
one terminal to battery +
the other to ground.(battery -)
Old May 13, 2009 | 11:03 AM
Fat Diesel's Avatar
Fat Diesel
The easy way is something like the one 3rd from the top on this link. I have something very similar plugged into my 12v accessory plug by my tailgate. I leave it in year round and know the voltage at a glance. It's nice because I play the stereo quite a bit in the summer when I'm working on all my money pits and the 12" subwoofer likes to suck down the juice!
Ice Alert: Thermometer : Digital Compass : Digital Volt Meter : Galaxy CB Radio : at RoadTrucker.com
Old May 13, 2009 | 11:27 AM
farmdad's Avatar
farmdad
I have this one in my truck. It works fine but definitely isn't high quality. I need to mount it and get the compass set as I have it just sitting on the dash now. I do like the digital readout for volts as I watch it when I am waiting for the glow plugs, then starting and watching for the GPR to cycle off. Without a volt gauge, I really feel lost as far as voltage status.
Road Pro On-Line
Old May 13, 2009 | 12:24 PM
Izzy351's Avatar
Izzy351
With a 2002 you can read volts from the odometer, but it's not a full-time deal. Resets to mileage every key cycle. To read cool stuff with a 2002 & up odometer, push & hold the reset button, then turn on the key and wait for the gauges to reset. Let go, and you can then press it & cycle through a bunch of stuff, like digital tach, battery V, lots of other stuff that I really don't know what they mean (some kind of hex-data, etc.)...
Old May 13, 2009 | 12:32 PM
MINER DOUG's Avatar
MINER DOUG
volt gauge
Thanks for all of your reply`s Doug
Old Jun 8, 2009 | 04:00 PM
Centauro97's Avatar
Centauro97
Found this thread searching for the same question as the OP.
Is there any disadvantage in tapping into a hot versus switched-hot for the voltmeter?
Will it cause a battery drain if hooked into an unswitched source?
Thanks,
Dave
Old Jun 8, 2009 | 06:06 PM
farmdad's Avatar
farmdad
Unswitched there would be minimal drain but be sure to fuse it. If you switch it, then you wouldn't have to worry about it when you are away from the truck.
Old Jun 8, 2009 | 06:22 PM
Centauro97's Avatar
Centauro97
Thanks, that's what I figured.
I'm thinking of adding one more gauge to pyro, boost, trans temp, water temp, and voltmeter.
What's relatively easy to tap into? Don't think I want to deal with fuel pressure at this point, maybe later. I have an FS2500 so I've already tapped into those oil access points.
Dave
Old Jun 8, 2009 | 06:56 PM
NEIowa's Avatar
NEIowa
Where would someboby find a list of everything thats shone on the odometer readout? I've heard of this before but don't what to try it and then do something that I can't undo. I can't even find anything about in myFord service manuals I have on DVD-ROM.
Old Jun 8, 2009 | 07:20 PM
big poppa's Avatar
big poppa
Now I just got to go out and try this now, heard about it before but gotta try it, lol. I'll be back in a bit..
