Sudden Failure yesterday...
that reminds me... my harness is burned, but I haven't changed it since I have a glow plug filament stuck, and I don't want it to just burn up the new harness. anyone know how to get it out? I've used pliers, shot it with penetrants, and I've been driving it like that for a few months now. I'm sure the truck would run better if I changed the harness. Thanks....
back to the real issue... Evan, did you get anywhere with the truck yet?
I'll update when I figure it out...
Rog
my work schedule is insane right now, but I might be able to make it out there with a borrowed scanner and IR gun after you get back.
Luckily I actually HAVE an "Infra Red, no contact thermometer" that a VERY GOOD friend gave it to me.
I don't have pics up yet but it's the plug next to the oil fill cap. Two of the contacts are totally burned up.
How can I fix this? I can replace the harness under the valve cover... what about the piece outside the valve cover???
Can I splice in a new plug on the outside harness???
you should be able to find each piece on this link
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 10">****** name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CRick%5CLOCALS%7E1%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Font Definitions */ @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:536871559 0 0 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} a:link, span.MsoHyperlink {color:blue; mso-text-animation:none; text-decoration:none; text-underline:none; text-decoration:none; text-line-through:none;} a:visited, span.MsoHyperlinkFollowed {color
urple; text-decoration:underline; text-underline:single;} span.Hyperlink5 {mso-style-name:Hyperlink5; color:#22229C; mso-text-animation:none; text-decoration:none; text-underline:none; text-decoration:none; text-line-through:none;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]--> Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals) (Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Harness "Wedge" repair (not sure of years it fits or what it looks like)
(Ford) 2c3z-14a163-ab
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)<o
></o
><o
> </o
>& also …here…. Powerstrokeshop.com
