Tranny fluid type help?
Old Aug 7, 2002 | 11:14 AM
guardian's Avatar
guardian
I have a 98' Explorer 5.0 awd with a 4r70w tranny. I was recently in a front end wreck which took out the tranny cooler. The dealer which repaired the truck refilled it with 4 quarts of mercon/dexron III. The tranny dip stick specifies mercon v and so does the owners manual. Well, a week and a half later the tranny goes out and the dealer says that the mercon dexron III is compatible and had nothing to do with it. I need some help to find if this caused my problem. Ford dealers here in virginia are clueless. Anyone have links to specifications between the two fluids? Would greatly appreciate it. I am in battle with them over "their" fluid specification. Thank You!
Old Aug 7, 2002 | 05:21 PM
skywagon's Avatar
skywagon
Just look on the trans dipstick and see what oil it says to use in that particular trans. If it says Mercon V, do not use fluid that is specified for both dextron 3 and mercon, only use for Mercon V. If it states just Mercon, then dex3 or Mercon will work but not Mercon V. Most of the older ones used type F which cannot be mixed with Dex 3, or Dex 3 cannot be used in a trans using type F. A good number of newer synthetics can be used for both applications but be sure to check with the oil mfg, (as most have had to repair trans under their insurance and will remember lol) The clutch material is the hangup with using the wrong fluid as it deterioates the lining material in short order, you may want to look at the cluches when they are removed and it should tell the story. rk
Old Aug 7, 2002 | 05:28 PM
billster316's Avatar
billster316
Old Jan 23, 2003 | 01:11 PM
jeff44ranger's Avatar
jeff44ranger
Good question :
That is unfortunate , I will keep you posted on the outcome of my fluid change. In the meantime: Take a look at my posting regarding your concern over mercon v by searching " jeff44ranger " .
FordCwazyGuy
Aug 27, 2007 07:27 PM
JFUSION
Escape & Escape Hybrid
Nov 21, 2006 08:34 AM
tnt4cat
Oil & Lubrication
13
Jan 7, 2005 07:25 AM
Joe Finn
1997 - 2003 F150
32
Mar 18, 2004 02:32 PM
jsn1997
Aug 31, 2003 05:41 PM
